polk 2.1
seabeerob213
seabeerob213 Posts: 1,843
edited November 2012 in 2 Channel Audio
i am currently putting together a 2.1 system to rock my barracks room, i have a psw 110 and have ordered a polk RTi6 pair and a denon 1911 avr(i also need surround option and hdmi handling capabilities) but the 2.1 is my area of focus, do you recommend wall mounting the 6's for front channel and 2.1 use or would a shelf/stand be better use, wall mount is a more feasible option at the moment, small room, 10x17 roughly, one snubbed corner 3 feet each direction, concrete walls and ceiling, tile floors
Post edited by seabeerob213 on
  • seabeerob213
    is 14AWG stranded wire sufficient(with the banana plugs of course),
  • Tbone289
    Tbone289 Posts: 661
    I don't recommend wall-mounting the mains. Having speakers that close to the wall usually results in a "chesty" midrange and possibly "boomy" bass. Stands will allow you to fine-tune that distance and the reflections off the wall. It usually doesn't require much space--something around 12" or so from the wall. You're also going to want to at least put a large rug on that floor if you can, as the reflections off the tile and concrete are not going to be pleasant.
    14 gauge will be sufficient, but 12 would be better...
    I have the Denon 1910, which is the older version of your 1911. If I were using it mainly for music listening, I honestly would choose something else. It's very HT-centric, IMO. It will be OK, just not ideal.
    What sort of source will you be using for music?
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • seabeerob213
    i have stated this in my other thread, will put here as well(not trying to talk down to anyone), im in the barracks on a military base and in less than two years going back stateside, and when i do i will have a 7.1 ht and a 2.1 audio system, and at the price i found that reciever for, i couldnt pass it up(not looking for an award winning HT, just a decent surround to watch some blue rays) also, i have a small rug, about the size of my budget actually, and my souce is primarily my zune hd with hd/optical dock, or my laptop with hdmi out and (better than nothing, but also not a real bragging point) the beats audio software
  • Tbone289
    Tbone289 Posts: 661
    OK. Sorry, I wasn't trying to knock your equipment. Actually, I bought the Denon for the same reason also (the price used), and it does a decent job in my 5.1 system.
    With that said, I would do 14AWG, but I would definitely use some cheap stands rather than wall-mounting if you can pull it off.
  • seabeerob213
    wasnt trying to accuse you of that, i havent ordered it yet, gtheyre having a sale on their sit, ordering it in ten days when i get payed, and my current set up doesnt allow for any position except wall mount, unless i get a tv stan, put my dressers under my bed and move my sub, and idk, or possibly wall mount my tv, and place the speakers slightly under it next to the center
  • seabeerob213
    think i will order the rti4 off the ebay store
  • devani
    devani Posts: 1,497
    if not too much price difference, I would go with Rti6....and that's what I have currently...mine are mounted 6" from back and side...
    wall mounting is fine and since you will be using it for two years, I don't see why it won't work for you...i run my RTi6 and CSi5 as small speakers and crossed them at 60-80Hz....
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • ALL212
    ALL212 Posts: 1,664
    I've had both 4's and 6's - go with 6's.
    Aaron
    Enabler Extraordinaire
  • seabeerob213
    the seller wont ship to fpo, so im not able to order them, i have since enrolled with a shipping company that will ship only to fpo, you order have it delivered to them, they send to you, but i ordered the 4's, and a couple months down the road i will swith tothe 6's when money permits
  • snake1
    snake1 Posts: 567
    Reading what you have or are planning in your sig, your gonna have a nice little setup in the barracks! Movie nights in your room is what it sounds like to me! Be sure to charge admission lol!
    AVR - Onkyo NR809
    500gb HD for MP3 and FLAC files
    Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
    Mains - Polk RTi12 towers
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    Movies and games - PS3
    TV - Toshiba 52" HD
    Every vehicle has one good nuetral drop in it
  • seabeerob213
    its pretty rad sometimes, need to mount my tv or speakers so i can position speakers better though, and maybe jump up a size with the tv, but suits me fine for FPS and blu-ray, my neighbor above tries to compete with his HT in box but fails,plus some better cables and the rti4 will be here next week, im excited about it, best part is all the building managers are friends so in noise complaints they try to side with me if its not during quiet hours, these sony speakers cant handle the higher end at volume though, they kinda go a high pitched ring/whistle sound to them, and get a lot of distortion with some of my music, cant wait to move them to surrounds, although considering putting one as a center for now
  • seabeerob213
    also have a 32 inch sony tv, but its a moniter only, not hooked into the system the pc's get taken in and out based on my needs
  • Erik Tracy
    Erik Tracy Posts: 4,673
    stands in a barracks room???
    :eek:
    I'd wall mount them :cheesygrin:
    I had my Rti4s and RtiA3s wall mounted - worked just fine - and that is why Polk designed the power port on the back the way they did.
  • seabeerob213
    will it seem natural with them mounted above the tv?
  • Erik Tracy
    Are you forced into mounting the speakers at some sort of height?
    What is the layout of the wall you plan on placing the tv and audio equipment?
    Can you raise the tv to match the height the speakers would be at?
    Just to give you an idea or two....this is what my rig looked like when I had my RTi4s wall mounted with my plasma
  • seabeerob213
    current set up wont allow, although looking int some different arrangements, the wall is 7' across then 45 degrees for 3 feet then 45 mor, the other corner is 90 degrees, i have a dresser 18 inches tall the tv, avr, spekers and xbox sit on now,the dresser is two pieces side by side, with a lip so the tv is stuck, unless i mount it, or mount the speakers, they wont be higher actully, just went and looked
