Tannoy SRM 12B vs Polk 10B
anti-doom
anti-doom Posts: 7
edited November 2012 in Vintage Speakers
Have anybody experienced a pair of Tannoy SRM 12B? How do they sound compare to Polk 10B? Any opinions would be appreciated. Thanks
Post edited by anti-doom on
    Welcome to Club Polk!
    A question for you: Are you Dr. Doom's Auntie?
    On a more serious note, I haven't heard that particular pair of Tannoys but others I've heard I would take over the Polks, especially with tube amps--they are ever so sweet!
    Others will chime in!
    cnh
  • Msabot1
    Msabot1 Posts: 2,098
    Not familiar with Tannoy, do have a pair of old 10'bs and they are still cranking out the music despite their age, bought in 85, they are holding up nicely. Although I've owned others,never found a reason to get rid of of this pair!
  • Shacky
    Shacky Posts: 113
    Anti-doom
    Do two negatives make a positive?
  • anti-doom
    anti-doom Posts: 7
    Shacky wrote: »
    Anti-doom
    Shacky,
    negative multiples negative then make a positive. but two negative add up together still make negative. So it depends. Still I do not quite understand your question.
  • anti-doom
    anti-doom Posts: 7
    The reason why I asked this question because I have a chance to get the Tannoy for $400/pair. If I get Polk for $100,then I will spend $100 to upgrade to crossover than another $100 to upgrade the tweeters. Total would be more than $300 for the Polk. That is why I need your opinions/suggestions before making decision. Thanks a lot.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    Get the Tannoys
  • bigaltx24
    bigaltx24 Posts: 141
    The Tannoys are great speakers and not easy to find. I would go with the Tannoys, if you don't like them you shouldn't have any problem getting your money out of them.
    Denon PMA-900V
    Linn Axis with Grado Red
    Cambridge Azur 650C
    Polk SDA-1BTL
  • halo71
    halo71 Posts: 4,632
    Tannoy. Although I've never heard those, I can not imagine the 10's besting them.
    --Gary--
  • chandler9a
    chandler9a Posts: 878
    I used to have the 10's and I liked them but as mentioned above, I don't think they would be better than the Tannoys... even modded.
  • Face
    Face Posts: 14,340
    Tannoy.
  • anti-doom
    anti-doom Posts: 7
    I tested both Tannoy and Polk. Polk has better bass but overall, the Tannoy sounds much better and music is more "natural" than Polk. Thanks for all replies from everybody, I got the Tannoy.
