psw505 ques.
marcpam
marcpam Posts: 228
i have a psw505 subwoofer. What do you guys recommend i keep my phase switch at, 0 or 180. Also i keep my volume and low freq. knob on halfway (1 o'clock position).
Post edited by marcpam on
  • gatemplin
    gatemplin Posts: 1,595
    edited May 2004
    Try both settings with the phase switch. Have someone else toggle the switch while you listen to music and pick the one that blends best with the main speakers.
    If you are using the receivers bass management, set the crossover at the highest setting.
    If you want to set the gain dial (volume) to the proper level, get a radio shack SPL meter and a Sound and Vision HT setup disc.
    Graham
  • up2youjoe
    up2youjoe Posts: 114
    edited May 2004
    How do you like the 505?
    No Kids Allowed
    cold, heartless, clueless, greedy 'young professional'
  • marcpam
    marcpam Posts: 228
    edited May 2004
    The sound if excellent. It sounds sort of like a bandpassed enclosure. I am mating them with my rti12 fronts and it sounds awesome. I have my sub running halfway and it is not too much base, just enough. I can't see why anyone would want anymore bass than what this thing can produce, unless you have an extremely, oversized room.
    VR3 Posts: 29,425
    edited May 2004
    The reason why people want 'more' bass isnt nessicarily volume, its more about extention.......
    When you feel 15-25hz......your ideas about bass seem to change greatly....
  • PolkThug
    PolkThug Posts: 7,532
    edited May 2004
    For me:
    0 phase
    12 o'clock sub volume
    Receiver sub out +2
    Regards,
    PolkThug
