Thoughts on 2 channel amp for home theater?
bansheesho
What are your thoughts on adding a 2 channel amp to my 5.1 setup? This is my first venture into external amps. Would it sound weird to power the left and right channels with an external amp such as an adcom gfa-555 but leave the center and the rears to be powered by the receiver (keeping in mind that the receiver is a sc-25).
I mostly use this for HT, but do listen to music as well. Setup is in my signature. The goal is to tighten up the bass and improve the overall sound stage, depth, clarity, ect. Also just for fun and the experience of it.
Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
Post edited by bansheesho on
Sounds like a good plan to start with. One of the main advantages (aside from the obvious) to putting your towers on an external amp is that you free up power in your AVR to use elsewhere like center and surrounds. It will not sound weird or unbalanced. Your question mirrors one of my main questions a few months back before I ventured toward external amplification. You'll probably love the results especially for music!AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it -
Those Kef's are pretty efficient running 91db@8ohms and are having no problems being powered by the SC25 ICE amps. This is where "welcome to the rabbit hole" comes into play because if you are looking for particular changes there are dozens of configs that maybe related and not neccesarily an amp will fix. First of all I would work on room and positioning tweeks, examples: toe in, spikes or no spikes, reflections, etc., setting with the SC25 may help conciderably....start cheap and work your way out. Timber matching your rears would also be a start.
Continue with posting more details on your room setup and settings and maybe some pics2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I did notice that the power recommendations were fairly low on the speakers when compared to some others (15-200w). My room is a nightmare for sound, and there isn't much I can do about it due to space constraints. I am not particularly unhappy with them.. I know they could sound better with a better room (its really not fair to them), but they sound nice even in a crappy situation.
If I can spend $250 and get some improvement and have some fun then it might be worth itPioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub -
I added a 2ch amp to my vsx-32. Best thing I ever did. Nice improvement for HT but a massive upgrade in the music department.HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator -
Being efficient doesn't mean they're easy to drive...it just means, they're efficient.txcoastal1 wrote: »Those Kef's are pretty efficient running 91db@8ohms and are having no problems being powered by the SC25 ICE amps.
I measured the KEF Q900's frequency response in the farfield with DRA Labs' MLSSA system and a calibrated DPA 4006 microphone. The Q900's voltage sensitivity is specified as 91dB/2.83V/m. My estimate was slightly lower, at 90dB(B)/2.83V/m, but this is still usefully higher than average. The speaker's impedance is specified as 8 ohms, but as fig.1 shows, the impedance drops to 4 ohms in the top octaves and to below 4 ohms in the lower midrange, reaching a minimum value of 3.17 ohms at 160Hz. There is also a combination of 5 ohms magnitude and ?42? electrical phase angle at 80Hz, meaning that the KEF does need to be used with a good 4 ohm?rated amplifier or receiver.
http://www.stereophile.com/content/kef-q900-loudspeaker-measurements"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I stand corrected, but you may have to raise the budget for a decent 2 chnl amp2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Yeah, I know $250 is chump change for an amp. I found an adcom gfa-555 locally that seems to be in good condition. I have also been keeping an eye out for carver amps in the $200-300 range. I understand that they are older amps and may need repair in the future.
I would prefer something like a parasound with a 12v trigger or a new emotiva, and maybe that is in the cards later on if I like what I hear. I am just interested in getting in the game at this point... test the waters.Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub -
I run a D-Sonic 1000S to my fronts and power the rest off a Sunfire TGA5200 with excellent results. I initially started with Outlaw M2200 Mono amps on my fronts, and they did very well for me also. Get into it, you will love separates.Shoot the jumper.....................BALLIN.............!!!!!
IMO - If your main usage is HT I would shoot for a 3-channel amp to run FL,FR,C and power all other channels with the receiver, or I would equally amplify all channels. Primary point being that the center channel in HT might be the most important channel to amplify.Do you hear that buzzing noise?
This is a great way to improve your setup , I got started on my journey to full blown separates with a Denon avr3200 ( They don't make em like that anymore) and an Parasound hca2003a and latter added Adcom gfa555 which I liked better on music at times for such an old amp, truly built to stand the test of time, go for it!
Allow me to be the PITA who suggests getting a Parasound instead - 2 ch or multi. There's a bunch on ebay atm (both kinds). Just moved to one from an Adcom GFA-545, and the improvement (for music) was quite noticeable. Quite noticeable. Plus, they've got "THX Certified" stamped all over them. The Parasound HCA 1000A has a bit less power than the Adcom GFA-555, but it's got a lot of current, and can be had for $200-$250.Marantz CD6004
Adcom GFP-750
McCormack DNA-1
Polk LSi9s
Signal Cable ICs
Blue Jeans cables -
All suggestions are welcome... I am also looking at parasound, sunfire, emotiva, carver.... Just keeping my eyes open for a good deal on something in the 200-300 wpc range. Ideally it would be a 3-5 channel amp but if i can pick up a good 2 channel I will jump on it.Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
http://chicago.craigslist.org/chc/ele/3385239430.html
The guy is a tad bit over the top in his description, but for 3 bones it's a decent amp.HT SYSTEM-
lsi 9's -
True but given the customized faceplate I would worry about what might have been added (or messed up on) to the internals"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Hahaha.... It sounds like he snorted a few lines before he wrote that. I was looking into tfm-25, 35, 45, 55 (and their gaugeless counterparts) ... Nothing good in the area at this time.. there were some good ones a while back, but it just wasn't in the cards then.Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
Anyone know if you can bridge a Sunfire Cinema Grand (200wpc 8 ohm x 5 channels) into a 3 channel amp with 2 channels to each front speaker and 1 channel to the center?
Are these good sounding amps? I would assume that they would be similar to the carver tfm series amps... yes no? Also, anyone know how hard it is to change the bulb on the gauge?Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub -
bansheesho wrote: »Anyone know if you can bridge a Sunfire Cinema Grand (200wpc 8 ohm x 5 channels) into a 3 channel amp with 2 channels to each front speaker and 1 channel to the center?
Sunfire stuff is good and lots of folks here have them. In regards to changing out the bulb I think its decently easy if your handy. CarverAudio.com/Forums is where you want to go as I am sure they have instructions somewhere. Bunch of us from this forum frequent that one, so you'll probably have a link shortly."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
