to upgrade cdp or not that is the question?
soundfreak1
soundfreak1 Posts: 3,414
edited November 2012 in Electronics
Boils down to this (i think?) have been advised that once my adcom gda 700 get the full mods ie, new opamps DIC installed and all other upgrades that the old cdp im using (yammy cdc 665) has a good lasar and motor and to get to the point of reaching a real sound improvement by way of a cdp upgrade would cost me in the area of a 600.00 investment (which isnt going to happen). Something like a transport like a rega or simular used unit and that something new in the 3/400.00 range wont do it either.does this sound like good advise or all wet? Any suggustions would be helpfull as i want to do the mods on my rta12c's next.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • BlueFox
    BlueFox Posts: 15,250
    Keep the CDP, use it as a transport, buy a DAC, and a good digital cable.
  • soundfreak1
    Got the DAC (gda 700 adcom fully modded.) bluefox.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • falconcry72
    falconcry72 Posts: 3,580
    The DAC makes much more of a difference in sound than the transport. If you want to spend money, spend it on the DAC... unless you don't the look/functionality/remote of the transport.
  • steveinaz
    steveinaz Posts: 19,546
    Transport differences are extremely subtle to non-existant. Don't waste money there.
