Spikes for SDA. Any advice
Dabutcher
Dabutcher Posts: 2,604
edited November 2012 in Vintage Speakers
Attachment not found.I have not done any mods to my new SDA 's yet. I thought about replacing flat disc feet they came w with spikes. Do they really help on carpet floor and where do you SDA owners recommend getting eight of them? The feet on them now really help moving them round so if there is no difference I will just leave them on. Especially when I plan most of the mods listed in the owners manual. I have been searching for some SDA's for a year now and Karma really slapped me up side the head. The previous owner liked the bass response w his Cerwin Vegas better. I caught his CL ad the night he lowered his price in half of what he was asking the previous month . Also I did not have to drive out of my suburb in St.Paul. A gift from God for sure! As always thanks. D
Post edited by Dabutcher on
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    At one time there was a group buy from this site.
    http://meniscusaudio.com/extra-points-p-1292.html
    Hope this helps
    Dan
    P.S. congrats on the SDAs.
  • zingo
    zingo Posts: 11,258
    Congrats on awesome speakers! Spikes do help, although not as much with those speakers given the weight. The popular choice seems to be spikes from Mye Sound, but I've never used them myself. A place like Parts Express also has a lot of options, just make sure you get the right thread pattern.
    Good luck!
  • brgman
    brgman Posts: 2,859
    I use these 1.50" with Herbies sliders.If you do not plan on moving them at all forget the sliders.
    http://www.oregondv.com/spikes.htm
    I’M OFFENDED!!!!
    F1nut Posts: 51,697
    Yes, big time!
    I'll have to respectfully disagree.
    Only issue with those is the tip is rounded off, which prevents them from piercing thru carpet.
    I use these 1.50" with Herbies sliders. http://www.oregondv.com/spikes.htm
    Those are nice, much better than what Parts Express sells.
    Also check out the spikes Adona sells.
  • headrott
    headrott Posts: 5,496
    brgman wrote: »
    I have a set of the 1.5" spikes from this company. The owner hand delivered them to me as they are located in Salem. Nice guy and the spikes they make are excellent. They have absolutely no problem piercing the carpet as the tip is very very sharp. Cut my leg open, sharp. I have moved the speakers (2.3TL's) around many many times without breaking the spikes and feel they are solidly built. I recomment these spikes without hesitation.
    Yes, big time!
    Agree with Jesse, but I haven't used the Adona spikes. They look very similar to the Brass and Granite Audio spikes.
  • PolkieMan
    PolkieMan Posts: 2,446
    These did not come with the Bass Brace Option?
    Toolfan66 Posts: 17,994
    zingo wrote: »
    Good luck!
    I have to disagree Mr Z... It was a night and day difference putting spikes on, the weight means nothing...
    Get some good spikes and spike them. IMO this is one of the first mods one should do even over crossover mods..
    Have fun!!
  • Dabutcher
    Thank you all again. I have heard of the bass brace ,but do not understand function or set up? D
  • hoosier21
    hoosier21 Posts: 4,415
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    F1nut Posts: 51,697
    The bass brace is a length of all-thread that screws into the back of the speaker. There's a bolt near the top, remove it, screw in the all-thread. Lock it in place with a washer and wing nut. At the wall end it came with a bracket that you screw into the wall. Run the all-thread rod into the bracket and secure with a washer and wingnut. Do not use the bass brace and spikes together.
    I used the bass brace at my old house with hardwood floors and plaster walls. My new house is carpeted hardwood floors with sheet rock walls. I use spikes here and prefer them greatly to the bass brace. I should have used spikes with floor discs at my old house. The issue I didn't like with the bass brace is the speaker can still move around to a degree, not so with spikes.
    IIRC, there's some mention of Matt Polk suggesting the bass brace would be his choice, it certainly isn't mine.
    F1nut Posts: 51,697
    Russ wrote:
    Yep, that's when I was using the brace. Never again.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    Just to be certain...the interconnect socket is pin/blade, correct? If so, the positive (red) binding post nuts should be on the left and the negative (black) binding post nuts should be on the right. Making this change (unless they are already correct to begin with) will result in a dramatic improvement in bass response.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • headrott
    What didn't you like about the bass brace Jesse? I haven't tried it, but have thought about it.
  • PolkieMan
    I have used mine ever since I have hard mine, A long time ago the kids were little and I liked it for the safety factor and I heard use one or the other not both so the brace I felt was the best for safety and sound together.
    headrott wrote: »
    Spikes make the bigger impact in all around sound, tighter more detailed bass. The only thing I like about the bass brace is the sturdy ness it gives these speakers, it is also easier to level them vertically.
    PolkieMan wrote: »
    That's BS!!! Use both.. At least try it.
    Spike them!!!
  • drumminman
    drumminman Posts: 3,396
    IIRC Darqueknight uses both and found there to be a bit of improvement in bass response.
  • Dabutcher
    Are my threads 6mm or 1/4-20? Thanks for all the help and advice. I love this Polk blog. Darryl
    pitdogg2 Posts: 26,959
    Dabutcher wrote: »
    1/4x20
    drumminman wrote: »
    I use both as well with no problems..
  • musky1963
    musky1963 Posts: 275
    I made mine from 1/4 x 20 bolts. I cut off the heads and ground them to a point. I am guessing they do the job just as good as the insanely priced "audiophile" grade spikes. :) .
    Jeff
  • TennMan
    TennMan Posts: 1,267
    I don't fully understand how the spikes work but I don't doubt they do. I intend to spike my stands for my 10's. I will have to put the discs under the spikes on hardwood floors. I would like to use something unique like a quarter or something instead of the plain disc if possible. Does the size of the disc make a difference in the way the spikes effect the sound?
    musky1963 wrote: »
    I would never put a 100lb-200lb speaker on 1/4-20 sharpened to a point bolts. I value my investment and $100+ on spikes that look better then a bolt is cheap IMO.. Price some brass rod then learn to run a lathe then come and tell me they are insanely priced..
  • musky1963
    I am not cheap, just not buying the machined and polished brass is superior nonsense. They are buried in the carpet, so what does looks have to do with how they funtion? Four bolts, protruding only 1 inch on end is not going to break. They dont need to be needle sharp. The inserts would give out 1st. Oh, BTW, I know how to use a lathe too and brass is very brittle.
    Jeff
    musky1963 wrote: »
    Depending on the alloy of brass that is used.. BTW I didn't call you cheap:confused: :cool:
  • PolkieMan
    So is there spikes you recommend?
    Toolfan66 wrote: »
    F1nut Posts: 51,697
    musky1963 wrote: »
    I used the stock steel spikes (basically the same as your bolts) provided with my SDA's before upgrading to Mye Sound brass billet spikes. I noticed a slight increase in bass response using the brass spikes. I remember reading about why brass is the preferred metal for spikes, but I don't recall where. If you're interested, I'm sure you could find it.
    I'll have to disagree that brass is brittle, it's actually a fairly soft and malable metal.
    F1nut Posts: 51,697
    PolkieMan wrote: »
    There are a number of spikes recommended in this very thread.
  • cincycat13
    cincycat13 Posts: 888
    Unfortunately I don't think mye sound still offers 1/4-20 IIRC and 5/16 UNC are not suitable to turn down. Those are the ones I finally decided on and I missed getting my order in by a couple of weeks. I know where the last of the inventory went and have been unsuccesful in getting them out of his supply as of date...but I always hope.
    Didn't have the $ when TF66 ran his. Maybe I'll try the meniscus...
  • Dabutcher
    Ordered eight from Meniscus. Red positive binding post is on the left as advised. There is no hole for brace on back top of my speakers? So I guess I will have to drill my own if I want to do that mod. Seems simple and cheap enough to try out? Thanks for all the help.. Darryl
