Bi-wiring SDA's
drumminman
drumminman Posts: 3,395
edited November 2012 in DIY, Mods & Tweaks
Interested in hearing the experience of those who do it and like it, or have done it and gone back to jumpers. What it your associated equipment - pre, amp, speaker cables.
I'll start the ball here - I'm bi-wiring and am getting such good results I haven't had the curiosity to try jumpers instead. I'm using the VH Audio recipe for braided Cat 5, using a 54 pair braid (27 wired each to + and -) on the lows and a 18 pair braid on the highs, using Belden teflon cat 5 wire.
  • drumminman
    edited October 2012
    I meant to post a 9 pair braid on the highs. The awg is 9 on the lows and 15 on the highs.
  • drumminman
    Come on, no one has compared bi-wiring to using jumpers on your SDA's:question:
    Fess up - let's hear what your experience was!
  • zingo
    zingo Posts: 11,258
    I prefer bi-wire simply because it doesn't use the jumpers, just a single terminated length of speaker cable for simplicity.
  • michael1947
    michael1947 Posts: 774
    I bi-amp my SDA-SRS for my HT. I don't know much about the SDA's yet and mine have been up-graded with new tweeters and crossovers. I tried them with my HCA 2200 in 2 channel with jumpersnot bi-wired and they were great but now they are in my HT and I use 2 channels of my XPA-5 for each speaker. I am using Signal Cable Classics for the hook-ups and I am satisfied. I'm not sure I (just me) can appreciate all of the little differences in a high end amp for home theater use as my attention is so divided between audio and visual. I (just me) think that if the speaker has the capability for bi-amping and you have the amps then you should so so. I have tried bi-wiring with my smaller SDA-A1's and RTIA9;s but returned to jumpers and MIT hook-ups for 2 channel. I think generally you are better off with a high grade speaker wire and high grade jumper if you cannot bi-amp. I am un-familiar with your home made speaker wire configuration but my (just me) thoughts are...If you can afford it go with the good stuff for the hook-ups.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • drumminman
    The geometry of this cable is what makes it special: it's a litz design (individually insulated wires) with all wires weaving from the outside to the inside of the cable continuously. This makes for a low inductance, high capacitance cable. From what I understand you want low inductance in a speaker cable, and low capacitance in IC's.
    It has a very clean, open sound with great imaging. Smooth top to bottom with no particular emphasis on any part of the audio spectrum. The problem is it's very labor intensive to make. I'm thinking about making the same design but out of higher grade wire (teflon OCC or teflon silver plate mil spec copper), but really don't want to do 4 wires if I can get away with just using a jumper.
    Bi-wiring is expensive :eek:
