Stand 38lb LCD TV on top of CSI A6??
mikemundy
mikemundy Posts: 1
edited November 2012 in Speakers
I want to have a CSI A6, flat side up, with shims (pehaps two rubber door stops) underneath the curved side to
prevent it from rocking and then stand a 38lb LCD TV atop it right on the flat side.
Does this sound reasonable?
If not any suggestions for a simple way to have the speaker under the TV?
Thanks in advance,
Mike
Post edited by mikemundy on
  • ambiophonics
    ambiophonics Posts: 727
    edited October 2012
    I wouldn't recommend trying to balance your TV like that, perhaps you could build a small shelf around the center channel - two legs on either side and a board across the top, then set your TV on that sturdy shelf.
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • chumlie
    chumlie Posts: 8,658
    edited October 2012
    NOT reasonable at all. Build the shelf.
  • Syndil
    Syndil Posts: 1,582
    edited October 2012
    Or, do it the right way and wall-mount the TV above the speaker.
    Something like this (not my photo):
  • ken brydson
    ken brydson Posts: 8,988
    edited October 2012
    Another vote for wall mounting. MP has some nice mounts for cheap.
  • ambiophonics
    edited October 2012
    Too bad about the bose speakers...
    Syndil wrote: »
  • Syndil
    Syndil Posts: 1,582
    edited October 2012
    Yeah it was the first photo I found... Same principle however. Takes a bit of work routing wires through the wall, but gives the best overall look IMO.
  • oldmodman
    oldmodman Posts: 740
    edited October 2012
    Wall mount would be the best.
    And this is the best reason. Flat screen TV do not like constant vibrations like a speaker generally produces.
    TV sets are loaded with surface mount components on their circuit boards. They seem to be the main failure points in flat screens TVs. I have repaired quite a few sets for friends. And it is always a surface mount component.
  • jbooker82
    jbooker82 Posts: 1,627
    edited October 2012
    TV Rider 2 but it isn't wide enough for a A6. You could always build one out of two oak stair treads. The font top and side legs would already have the rounded edge.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • cowtrimmer
    cowtrimmer Posts: 201
    edited October 2012
    Do the deal with doorstops and post pictures first :lol:
  • KiTsuNe
    KiTsuNe Posts: 74
    edited October 2012
    Something like this? But larger and with the center under it?
    HT: M5510-Prox2/PN51E550/NR708/M282(3)/RTi A7/CSi A6/FXi A6/DSWPro660x2/PS3/HTPC
    Office: Belkin PF60/PN43E450/Marantz 1501/PSB 400/Image C4/WD Live TV
    2-Channel: Yamaha C4/M4(2)/DQ-10's/DQ-1w(2)/SBT/Pioneer R2Rl/Technics SL-7/AR EB101
    Desk: QSC RMX850/Behringer B2030P
  • codyc1ark
    codyc1ark Posts: 2,535
    edited October 2012
    Kit, is that an energystar sticker on your tv still? Why?
    And what the hell is under that super entendo'?
  • Syndil
    Syndil Posts: 1,582
    codyc1ark wrote: »
    It's an ancient device I believe was once referred to as a VCR by prehistoric man... Obviously Kitsune is a big anime fan, and probably has some on VHS. I'm an anime fan myself, but I don't have any on VHS... or resin figurines.
