Should I upgrade cars electrical??? or Just big 3 upgrade?
LeaF
LeaF Posts: 15
edited December 2012 in Car Audio & Electronics
So having done some research I am doubting myself as to if I need the Big 3 upgrade, a new battery, or alternator or cap or anything else.. So much confusing information out there for a beginner :redface:.. very frustrating :mad:... I am thinking I will be Ok with solely the big 3 upgrade and I may not even need that :question:... But my additions to stock vehicle are as follows
- Polk SR-104DVC
- Polk PA D1000.1
- Knukonceptz Fleks 4 gauge Wire
My car is a 2013 Nissan Altima... The stock Specs that matter in this case are
- Battery - 550 CCA
- Alt - 110 amp
I don't know if the Carputer and the Sub and Amp set @ the 700W RMS (I obviously won't be frequently hitting that... But would like to have the option to crank it you know...) if it will put the cars electrical at risk...
I know i've asked a couple questions prior to this one... So thank you guys for your help thus far! (MacLeod, Arun, Irish Champ and Vital) And thanks in advance to anyone for sharing you knowledge on my current dilemma haha.
  • exalted512
    exalted512 Posts: 10,734
    edited October 2012
    Always start cheap and work your way up. Do the big 3 first. If you're seeing your voltage drop a lot, get a bigger battery. If you're still having issues, THEN upgrade the alternator as a last resort.
    -Cody
  • LeaF
    LeaF Posts: 15
    edited October 2012
    exalted512 wrote: »
    -Cody
    Thanks for the reply Cody! Now I guess what I am wondering is based on the items I am installing and what the car comes with stock do you think I would even require the cheapest upgrade (being the big 3) or would I be able to get away without... I could ask the installers but I know they will just say do it because that's more $$ in their pocket...
  • Systems
    Systems Posts: 14,872
    edited October 2012
    I would skip the cap...............for now.
    IMHO it should come much later.
    I have ran some very good systems (mucho $) and have never needed a cap.
    I have nothing against them and actually like em, but that would be my last step.
    Alternator, cable, and battery will make a huge difference.
    Hell you are not going to listen very long without a good battery.
    Make a "GOOD" ground with everything, meaning no "inside" grounds.
    Actually drill the smallest hole you can get away with through the frame somewhere, sand it with a 4" inch angle grinder (both sides if possible), and run your ground through that.
    Biggest mistake I have seen with some other "good" systems is grounding it on a seat belt plate, or some other "in cab" point.
    "Ground" that system to the frame.
    Makes a marked difference.
    You can get some good "juice" with the above, THEN your cap will thank you!:cheesygrin:
    Testing
    Testing
    Testing
  • arun1963
    arun1963 Posts: 1,797
    edited October 2012
    Capacitors are worthless. Just stick to what Cody said, if you need to go that route. In most cases even the big 3 would not be required.
  • KaosTsoc
    KaosTsoc Posts: 372
    edited October 2012
    Getting a deep cycle battery is a good investment, and will help with current draw. A good battery would be something like an optima yellow, or blue top, Kinetik, XPS, or Stinger. All these batteries are deep cycle one, take a few, and look them up, and look at price, and see what fits your budget. There are a few more companies that make these, but cant think of them. As for the big 3 upgrade. It is a good upgrade if you notice head light dimming. All it does really, is help with current flow mainly. You would only need to upgrade your battery, alt, and wires if you were using something 1800-2000+ watts. With the current amps from your alt, and the battery, I think you will be just fine. Hope this helps.
    Thanks.
    2006 Prerunner Access Cab
    5 Speed 4 cycl 2wd
    Audio:
    Pioneer P860 Head Unit
    Polk Audio MM6501
    Alpine PDX F-6
    Two SR124(SVC)
    Alpine PDX M12
    Kinetik HC2000 battery and Sleeve
    200 Amp Mean Green High Output Alternator
    Need a DJ, photobooth, or both for rent?
    http://photoboothdallas.org
  • PerfectCreature
    PerfectCreature Posts: 1,456
    edited November 2012
    Like they said, do not get a cap. It is like a band-aid that provides no real sollution. Sure it helps, but it does not fix anything.
    Do the BIG 3, then if it still does not help. Invest in a name brand battery, I like Kinetik as I have had zero trouble with any Kintetik battery I have had.
    Then, I would look into a larger alternator.
    Keep in mind though, your alternator only starts charging once you hit roughly 1500rpms and above. So if at idle your voltage drops, it is only normal.
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • LeaF
    LeaF Posts: 15
    KaosTsoc wrote: »
    Ok so I will test out the system with the stock cables and see how it goes then try big 3 then battery but hopefully ill be good! Thanks for the info man that's the track I was going to take buti just wanted to make sure!
  • frosty2k
    frosty2k Posts: 39
    I'm not sure where you are located, but I'm in Canada and bought an Eliminator battery from Canadian Tire. It's got a 7 year warranty. Its not a deep cycle but even if I burn it out through draining to the bottom and recharging, they will replace it. Unless your doing competition, a decent regular battery should do the job.
    As far as damaging your electrical system, this is extremely unlikely unless you wire the system incorrectly, and even then its a stretch, you'll likely blow the amps before anything happens to the car. Per my battery note above, the worst you would do in a correctly wired setup (reds to reds, blacks to blacks etc) is excessively drain the battery.
    I'm running a system that is fused at 110 amp (50+60). The amp you mentioned is fused at 120. Your ears may be different, but when i'm at 3/4 power I'm calibrated to maximum recommended power, and its fairly ear bleeding and I have no major electrical issues running off a 95 amp alternator.
    If it doesn't perform to the way you want it to after getting it all in the way you've planned, then I would start considering addional parts.
    /////ALPINE INA-W900 HU
    /////ALPINE PXA-H100 DSP
    polkaudio SR5250
    JL Audio HD600/4
    polkaudio SR124DVC
    JL Audio HD750/1
    "In this house, we obey the Laws of Thermodynamics!"
  • Bugstyvy
    Bugstyvy Posts: 119
    Where do you get a beefed up alternator?
    Mcintosh MC2300
    Mcintosh 2105
    Integra Pre amp 9.8
    Pro-ject Record Player
    Sony 200 disc CD Changer
    Basic Wiring
    60" Samsung Series 8
    SDA-1.2TL
    SDA-3.1TL (unused at the moment)
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    Some shops will do custom windings.Check the shops in your area.I picked one up for my old truck a few years ago.
    Dan
  • Sherardp
    Sherardp Posts: 8,038
    I would do the big 3 and battery from the start. For your Altima I would do the XS Power D3400.
  • exalted512
    frosty2k wrote: »
    You really can't compare a 'system' at 110 combined amps to a single subwoofer amplifier. It's going to draw a lot more and is going to do it at peak intervals, not spread out.
    And theoretically, your fuse at the battery is based off the size wire you're using, not the amperes your amplifiers are drawing. You didn't specify what you had done one way or another, just thought it would be worth noting.
    -Cody
  • LeaF
    LeaF Posts: 15
    Hey guys!
    So I got my system installed finally! I didn't end up getting the Big 3 or new battery / alternator. And everything's working great so far no light dimming (even when running high beams, seat warmers, AC and interior lights) and I never plan on playing it with the car not turned on so I am very excited about it but I noticed something.. I don't know if I am just over analysing this... But I figured since i've never had a system to compare to that I may as well ask you guys...
    So the stuff listed above is installed:
    - Polk SR-104DVC (custom built enclosure to spec)
    - Polk PA D1000.1
    I also got this axxess ADCT2 in order to hook my amp up to the stock Blose system....
    http://www.sonicelectronix.com/item_26694_Axxess-AX-ADCT2.html
    Now what I am noticing is that my sub is not playing loud like i thought it would... I don't know if its because of the fact that its hooked up via the rear channel with the LOC or what... But My cone does not even begin to move and I don't hear the sub making a difference until i have the gain a HAIR below halfway which I felt kind of weird... I also turned the gain to max just to hear and the amp does not clip... Do you guys figure the amp isn't getting the power it should? or am I just being anal and foolish? I mean it still hits hard as F*** but Not what I was thinking... I have the Factory bass settings set to 0 I can turn them up but it doesn't make a big difference for the SR it just makes the Bose speakers sloppier then Lindsay Lohan... Do you guys figure I should have got something like the Rockford Fosgate RF-BLD or I dunno... lol Maybe its normal...
    Thanks for taking the time to read and for your input guys!
  • eloplayspolo
    eloplayspolo Posts: 1,117
    I don't remember but does that amp have input levels?
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
