What would y'all do????
snake1
Well Polk folks, I'm in the midst of a dilema... I have the $$ for one of 2 things right now. Either a Parasound 2250 amp or an SVS PC12-NSD subwoofer. I will eventually have both, but I just can't make up my mind on which to get now. My RTi12s would love the power for sure and I'm sure it would help the bass coming out of them profoundly! But, I would also love the house shaking SVS. What would you do and why??
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
Post edited by snake1 on
This is based solely on my opinion...and I am no tech or an audio expert. I would buy the amp. I think it will bring your RTi12's alive. After you are getting more life out of them, then you can decide what sub you need. You'll be surprised how much more sound you get out of them. And me personally...I always have better luck running across speakers than I do good amps.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects -
Well...I just moved to an older model Parasound - HCA 1500A - from an Adcom GFA0545, and the improvement in sound quality is astounding, without a significant difference in (used) price. Can't say I have any experience with that sub.
The 2250 is part of the New Classic line, if I'm not mistaken. Are you buying it new, or used? How much do you have to spend? And what amplifier would you be leaving behind, if you got the Parasound?Marantz CD6004
Adcom GFP-750
McCormack DNA-1
Polk LSi9s
Signal Cable ICs
Blue Jeans cables -
I'd suggest getting the Parasound and getting your front and back end settled up as a subwoofer is easy to do, at anytime. There's no rocket science with a solid subwoofer but finding a really good amplifier can be work and hard to find the right one. The Parasound is an excellent choice and most likely the last amp you'll buy. PLUS you'll get better performance from EVERY speaker in your setup and not just be augmenting bass. As a side effect, the better power will allow your RTi12's sound much better as well in regards to the bass response and while NOT a substitute for a dedicated subwoofer....DUH, I think you'll notice an increase in tighter, more accurate bass in the RTi12.
This opens up multiple amplification options using your Onkyo as well since you can re-assign channels.
I'm very interested if you choose the amplifier but not so much if you just buy the subwoofer. Not that it's an SVS but that's the easy way out to me and if you've put this much effort into your system already, get the core of everything solid and spot-on. The subwoofer is just so simple to figure out.
MarkCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Bthogan, not leaving anything behind. Its my first foray into separate amps. My 12s will be leaving the AVR i suppose ;-)
Mark, this is giving me a lot to think about! I've got about 700-800 to play with. I have found a 2250 that could be had in that range believe. Is an amp a real night and day difference?
Keep it coming guys!! And thanks!AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it -
A parasound is a real diff. Get the ampMain Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Snake,
YES. I know the Onkyo is a capable AVR but it's no substitute for a dedicated amplifier. You'll find that same comment on this website hundreds of times from hundreds of folks. Good luck in what you decide but I assure you, the amp is the best decision at this point. Especially with what you have assembled in regards to gear and loudspeakers so far. You have a great system ready for the next step, and it's not a subwoofer.
EDIT: TRULY capable AVR's exist but they're few and far between when it comes to reality and a fidelity firewall. Onkyo, NAD, B&K, Pioneer ELITE, Integra are all AVR's that I'm comfortable with pushinmg loads higher than rated but there is simply a limit at which you can push anything. The fact you can remove all that power for a couple speakers, or a few speakers, changes the whole game and will result in better sound across the board. Let alone other benefits so there's just nothing but a win-win situation here. A subwoofer gets you 10-15hz bass.....that's it when it comes to the big picture. Big F'n deal. You can do that later.
Trust me, the amp! I had a set of Rti12's that I was running in a surround system being pushed by a 140WPC Yamaha AVR. Then I heard them with a Carver TFM-25 and they didn't even sound like the same speakers. They woke up and came alive. If you ad a sub, you can ad some more low end, but your 12's are still being way under-utilized. Get the amp and you'll never look back.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Get the amp and don't look back!!!
Get the amp first. I started powering my RTiA7's with a AVR. When I moved to the 2250 it was a significant difference in SQ. Output and bass response is very good with the amp. Besides purchasing the speakers this has been the best upgrade I've made to date. This should satisfy you until you have the funds to purchase a sub._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
I would buy the Amp because I already have the SVS and the house does shake! I am going to get a Parasound later, but if I didn't have my SVS I would still get the SVS first...its that good! :cool:Anaheim Hills CA,
HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Amp,Amp,Amp,Amp! Speakers will come alive as if you bought a new pair! And you'll be doin a little dance like when you first got your license!"Everything I ever did in my life worthwhile I caught hell for"
I'd get the SVS first. It adds so much to movies that the amp just can't do. I've ran my a9's on just a receiver and dual subs with great results and it added the most to my system over adding an external amp. Now if this system was a music first system then I'd get the amp because the 12's are very capable down low.
So for HT sub first amp second, and for music amp first sub second. -
Amp first and formost. As Thorton pointed out it will be the most significant upgrade that you will make.
Powering your towers to their full potential will also help with getting more bass out of your speakers that you are not getting now. So it will help with both music and movies.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Well, the consensus seems to be amplifier so I'll check to see what kind of deal I can get for it. If it doesn't work out I'll probably go ahead and get the SVS for the time being. We'll see where this goes! Thanks for the input! I must admit, I really do want to see the 12s really sound like they look (if you get what I mean). I'll report back when I get one or the other coming.AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
Get the sub now
...amp later when you find a great deal. -
I'd get the sub especially if you're into home theater, I don't think you can have the full experience without a good subwoofer to handle the LFE.
Amp first.
Well 2 things.
1. I have found what could be a good deal on an amp
2. I'm mainly 90% music and 10% movies. Movies will play a bigger role later down the road. Thats why I'll eventually have both.
ps. what would really be sweet would be a new Parasound 5250v2 and just be done with amping all together.......but don't have 2300 just to blow.... :sad: :cheesygrin:AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
If you're 90% music I change my vote to amplifier first!
I own both the Parasound 2250 amp and the SVS PC12-NSD subwoofer. Get the amp first, then the sub, I used to run a set of RTi10s off a Pioneer Elite AVR and when I added the Parasound the improvement was quite evident, particularly the bass. The addition of the SVS really added some nice depth to the bass while staying tight and musical, and yes the SVS kicks butt for home theater. I no longer run the SVS sub for 2-channel after swapping out the RTi10s for my Linbrook Sig Systems, the bass impact out the Tylers is crazy good.2-Channel System
Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
Spkrs: Tyler Acoustics Linbrook Signature Systems -
I have to say sub, because I want an svs and I already have my Parasound. No seriously though grab an amp first Doro makes all the right points.
Obsession18 wrote: »I own both the Parasound 2250 amp and the SVS PC12-NSD subwoofer. Get the amp first, then the sub, I used to run a set of RTi10s off a Pioneer Elite AVR and when I added the Parasound the improvement was quite evident, particularly the bass. The addition of the SVS really added some nice depth to the bass while staying tight and musical, and yes the SVS kicks butt for home theater. I no longer run the SVS sub for 2-channel after swapping out the RTi10s for my Linbrook Sig Systems, the bass impact out the Tylers is crazy good.
What freq did you have your crossover set at Obsession?? 80hz??AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
I only use my sub for movie's not for 2 - channel music. I cross over at 80 Hz and use the plus setting on my Pioneer Elite which also runs my mains at full range. When you have the LFE signal running to both the sub and your mains you have to make sure you have the sub in phase with your mains, playing with the phase knob on the sub will get you there, if your out of phase you will have week bass even with the SVS.
I find running the LFE to both my SVS and my Linbrook Sig Systems skakes the room even more.2-Channel System
Yeah, at 90% music...it's a no-brainer.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
I would get the amp., especially if you listen 90% to music. The better amplification will bring out the musical bass and deal with the house shaking bass from a sub. later.
Does $800 sound fair for a like new 2250??AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
Yea $800 sounds fair but I would offer them $700, new they run $1350, I got a demo unit from a local dealer for $1000.2-Channel System
Def amp first for 90% music!!
Get the amp first.
I have an Onkyo 709 and at first I got a Parasound 2125 to power my RTi12s and it sounded a lot better than the Onkyo. A few weeks a go I got a good deal on a Adcom 585 and the RTi12s really came alive with this amp, most of the time I barely use my sub for music now and only the 12s.
CheersHTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
Its not looking too good on the Parasound deal... I put in a best offer on ebay, first one washed out and I did it again for 800... no response and it goes out tomorrow around 11. I'm going to put in a call to Emotiva and ask some questions about their XPA2 if the Parasound doesn't work out. The SVS is still in the back of my mind though.AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
