burning cds -i net radio
leftwinger57
I just noticed a minor difficulty w/ trying to burn a cd of mine. What I do is go to my library p/u dozens of CDs and
import them into my I-Tunes library.Then sync to my I-Pod and dock it into my big system.To burn I go into Windows Media Player drag the album to spot, line it up and hit burn and no problem.Now I tried this w/ Springseen Seeger
Sessions and it will not copy to save itself. The copy is good because it does play at the computer but 1. why
won't it burn and 2. how come media player does not go out from the computer to other sources like the dock or
I-net radio does.
Listen I'm no literate computer giant here so be as gentle as possible if there is a solution.
I-net radio does.
Some kind of protection, or just not right....
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Is it possible that this one cd is somehow encripted if that's the word.Also I just noticed that the album is not imported first through
I-tunes and not in that library. Maybe I'll get another copy but mostly if it's seen it before it immeditley rejects it and says you copied already moron.So maybe delete the entire cd and try again is what I see in my future.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
