Rti4, Rti6, or Rti8?
johnny_utah
johnny_utah Posts: 117
edited May 2004 in Speakers
so here is my question...
I recently purchased the CSi3 center channel to replace a Sony center that I had, and I am very pleased with he sound. I want to replace my front and rear speakers now. I can’t decide wether to get RTi4’s, RTi6’s, or RTi8’s for the front speakers. I know that I am going to get the 4’s for the back. I have a great Infinity 12” sub that gives me plenti-o-bass, so I want as much clarity out of the fronts a possible. Will I get better sound clarity out of the 4’s, 6’s, or 8’s? I have an Onkyo 601 receiver that I love. Any suggestions?
Thanks.
Post edited by johnny_utah on
  • steveinaz
    steveinaz Posts: 19,546
    edited May 2004
    I would go with the Rti6 or 8, depending on what you want to spend and the room you have available. Since you already have a good sub, why not get the midrange clarity of 2-way? (Rti6). They handle plenty of good clean power, they would be my personal pick...
  • Willow
    Willow Posts: 11,276
    edited May 2004
    I would go the 6 way as well I have the 4 and now wish I had the 6. Once you get them be sure to drop the jumpers and make your own......but one thing at a time.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2004
    Do you do music or HT primarily? That may be a factor as well...
    I'd definitely go with either the 6 or 8. How big is the room they're going in?
  • johnny_utah
    edited May 2004
    The size of the room is about 14' x 18' or so. It will be used 95% for HT but my wife will occasionally listen to the radio.
    what does this mean "Once you get them be sure to drop the jumpers and make your own" gotta link to another thread?
  • AsSiMiLaTeD
    edited May 2004
    honestly I'd just go for the RTi6s...
  • johnny_utah
    edited May 2004
    why are you leaning toward the 6's? Are they really better than the 8's?
  • AsSiMiLaTeD
    edited May 2004
    I personally like the sound better from those bookshelf speakers...
  • johnny_utah
    edited May 2004
    I looked at the thread above. What exactly does that do? Is it needed if you are going directly from a receiver to the speakers? Is it necessary for the Rti6's?
  • johnny_utah
    edited May 2004
    also thanks for everyones replies. I feel a lot better about getting the RTi6's now.
  • Willow
    edited May 2004
    it's not required but it will help, and its not that tough his was just very well done. Mine are well done but with no banana plugs just bare 12awg wire.
  • steveinaz
    edited May 2004
    Johnny_Utah:
    One drawback of tower speakers (most, but not all) is that larger cabinets tend to be more sensitive to resonance. It's easier to make a small cabinet stiffer, less resonant; also, removing the resonance of big woofers sharing a cabinet with midrange/tweeter drivers can also enhance soundstaging and articulation in these frequencies.
    As with everything, there are tradeoffs; small enclosure--less bass but better articulation; large enclosure--compromised midrange/highs but deeper bass. Of course these limitations can be overcome; and this is what you pay for in the "mega-buck" speaker bracket.
  • WJE
    WJE Posts: 27
    edited May 2004
    I picked the RTi8 speakers over the RTi6s. I'm glad I did. If I had picked the RTi6s, I'm sure I would kick myself for not getting the bigger speakers.
    As each week goes by, my RTi8s keep sounding better and better. Last night, I had some Boney James in about 10:00 P.M. and the sounds were so good. I actually thought my neighbor was going to come over and tell me to turn it down because I'm running 2 subs.
    The sound stage is incredible with these speakers. :)
  • tasdisr
    tasdisr Posts: 32
    edited May 2004
    I like the Rti6. I just purchased a pair of Rti6's , a Csi3 center speaker and a psw 404 subwoofer and I am very pleased with
    the sound of the Rti6's.
    Mains - RTi6
    Center - CSi3
    Surround - Polk OWM3
    Sub - DSW PRO 550wi
    AVR - Onkyo TX-SR809
    Movies/Games - Toshiba HD A35 & Sony BDPS590 BluRay
    Music - iPod
    TV - Sharp LC-60C8470U
  • Belling
    Belling Posts: 12
    edited May 2004
    I can see why the RTi6 would be a better speaker than the RTi4 for 2 channel stereo, but would it make any difference in 5.1 surround? They both have the same tweeter. The only difference seems to be that the RTi6 has a larger mid/woofer and goes down to 40hz rather than the 50hz of th RTi4. But if you set your sub at 80hz or 100hz (I can't set the sub out on my AVR below 100hz) why would the RTi6 be any better than the RTi4?
  • AsSiMiLaTeD
    edited May 2004
    Becuase you have more of your sound coming from the directional speakers in the front. But the main advantage it has is for audio...
  • Early B.
    Early B. Posts: 7,900
    edited May 2004
    If these speakers are mainly for HT, get the 8's. It's best for the boom factor.
    "God grooves with tubes."
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited May 2004
    Ughhh ... he's got a sub which hopefully is doing the low end well as opposed to doing anything boom related.
  • Willow
    edited May 2004
    just save your cash go with the 6's you have a sub for the low frequencies the mids on the 4's are good but better on the 6's don't go with the 8's
