Parasound HCA-1206 Amplifier
swegyptian
Hi all,
Like many of you, I have too many things. I want a new AVR, so I am going to sell this amp to assist with the justifications.
It is really clean, in fact I think what you see on the faceplate in the picture is just assorted dust and such. It has never been rack mounted. I don't have the box, but I am one very picky packer, so no worries on getting it to you if I need to ship it.
I've seen these sell for $550-$600, so I'll go with $500 plus shipping from 61820.
Here is a generic spec list pulled from somewhere else:
SPECIFICATIONS
Continuous Power Output > 135 watts RMS x 6, 20 Hz - 20 kHz, 8 Ω, all channels driven
> 200 watts RMS x 6, 20 Hz - 20 kHz, 4 Ω, all channels driven
Continuous Power Output - Bridged > 350 watts RMS, 20 Hz - 20 kHz, 8 Ω, each bridged channel, 3+4, 5+6
Current Capacity: 30 amperes peak, per channel
Slew Rate: > 130 V/?second
Frequency Response: 12 Hz - 120 kHz, +0/-3 dB
Total Harmonic Distortion < 0.07% at full power < 0.03% typical levels
IM Distortion: < 0.04%
TIM: Unmeasureable
Dynamic Headroom: > 2 dB
Interchannel Crosstalk: > 75 dB at I kHz > 56 dB at 20 kHz
Input Impedances 50k Ω per channel, without looping inputs 1/2 to Ch. 3/4 or Ch. 5/6 25k Ω per channel, if looping inputs 1/2 to either Ch. 3/4 or Ch. 5/6
17k Ω per channel, if looping inputs 1/2 to both Ch. 3/4 and Ch. 5/6
Input Sensitivity: 1.0V THX Reference Level
S/N Ratio: > 118 dB, input shorted, IHF A-weighted
Damping Factor: > 800 at 20 Hz
Dimensions: 19" wide x 7" high x 18.5" deep (7-5/8" high with feet)
Weight: 71 lbs. net
SPECIFICATIONS
TIM: Unmeasureable
Weight: 71 lbs. net
Post edited by swegyptian on
That's a nice amp. Wish I could justify the purchase. Someone will get a nice new toy. GLWS2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
Bump.
Couple of questions:
What part of CIL are you in?
Also what would be the best way to power a front stage with this? Bridge channels 3/4 and 5/6 for the mains and then use either channel 1 or 2 to power the center? These would be 8 ohm speakers so I would guess that the front two would be getting 350 while the center would only be powered by 135?
Thanks in advance -
teamjhertz wrote: »Couple of questions:
Thanks in advance
You could in theory use 2 of the channels to power each speaker.... IMHO though I would just run all 5 channels off it and be done. The 6th could be used for a DIY sub, or just left alone."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
You could also bi-amp your front speakers with 4 channels, and use one for the center. I never bothered bridging it for mine, as I felt it was sufficiently powerful in the standard mode. Even at 135 per channel that beats out 99% of AVRs. And there is no harm in not using one channel...
I'm in Champaign. -
OH MAN YOU SUCK!!!
Not only do you have a very nice amp you're way too close for my comfort.....
good luck -
Im interested. I'll pm after work today.AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it -
Whew... glad someone's gonna snag this before I succumb to temptation.
Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Def man! Been looking for something like this. Bridging some channels too!!AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
I'm happy to meet you if you're close, and I will be driving to the northern burbs of Chicago early next month. ;-)
kuntasensei wrote: »Whew... glad someone's gonna snag this before I succumb to temptation.
Yup, he's not too far from me and he had me eyeing a couple trade options lol...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
yep me too...I was almost sweating:razz:swegyptian wrote: »I'm happy to meet you if you're close, and I will be driving to the northern burbs of Chicago early next month. ;-)
45 minutes away Bloomington. I also go to sailfin petshop quite often, I also used to live in Chambana. -
Your much closer than me, but I tend to make trips that way on occasion due to work and visting Corporate Headquarters which is located there."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I could meet you at Sailfin, haven't been there since I took down my reef tank.
Im not close... But I'll give u a shout later when i get home.AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
PM sent.AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
Forgive me, I didnt see that teamjhertz had already spoken. I'm interested if he backs outAVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
I'm kinda' glad if this thing has sold... 'cause I just got my HCA-2003 in today from another forum member, and after listening to how it sounds with my speakers, I probably would have snatched this up with a quickness tonight!Equipment list:
Emotiva XPA-3 amp
Still available!
swegyptian wrote: »Still available!
If all others in line before me have passed, are you open to trades + cash or are you looking for cash only?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Kuntasensei is pondering.
But if he passes I am always open minded to trade offers, so don't hesitate to ask. -
swegyptian wrote: »Kuntasensei is pondering.
If he passes, let me know via PM..... I might be interested in this beast and would be willing to drive to pick it up."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Your PMs are full, swegyptian, but what I was gonna ask was... Paypal okay for payment? Your original post doesn't say, and I've just been assuming such.Equipment list:
Emotiva XPA-3 amp
Yep, PayPal is great.
I am going to have to pass on this great amp. Good luck with the sale.
PM sent"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
It breaks my heart to pass on this, 'cause it would've made for a hell of a 9.1 setup (and I actually woke up this morning thinking, "Why the hell didn't you just buy it?"). I just can't justify it so soon after buying the HCA-2003 (and I would have to do major rearranging and spend a bunch on ICs). Good luck with the sale! And if this sucker doesn't sell by next month, maybe the voices in my head will override my common sense. :razz:Equipment list:
Emotiva XPA-3 amp
I lied. The voices in my head... they totally won.Equipment list:
Emotiva XPA-3 amp
^^^^^ lol
You SHOULD laugh, leroy! I'm gonna use it to power F/Xi30 side surrounds and RTi28 rear surrounds and heights! Probably total overkill... but screw it! :biggrin:Equipment list:
Emotiva XPA-3 amp
