Another newbie question: amps for 4ohm speakers
crouse
If an amplifier only gives power specs as into 8ohms, is there any other spec that will tell you if it can easily power 4ohm speakers?
Post edited by crouse on
A rule of thumb is that if a spec is missing then it is not supported. 4 ohm speakers are common, and amp manufacturers know it.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Which amp are we talking about exactly ?HT SYSTEM-
lsi 9's -
Never heard that one before. -
Not supported may be a little harsh but you can bet the performance is NOT as good as you would hope. If it was, you can bet the mfr would be listing it in the specs.A rule of thumb is that if a spec is missing then it is not supported. 4 ohm speakers are common, and amp manufacturers know it. -
Hate to quote myself, but untill we know this, everyones just guessing.HT SYSTEM-
lsi 9's -
Maybe current capacity, or peak current capacity. It's in amperes. The higher, the better.Marantz CD6004
Adcom GFP-750
McCormack DNA-1
Polk LSi9s
Signal Cable ICs
Blue Jeans cables -
Sorry, been away from the computer. The question specifically concerns a Music Hall a15.2
Thanks -
Something with autoformers would work.
I wouldn't drive current hungry speakers with that amp as it'll overheat (LSi15), but there are many easy to drive 4 ohm speakers (Klipsch) that would be fine.
