Another newbie question: amps for 4ohm speakers
crouse
crouse Posts: 34
edited October 2012 in Electronics
If an amplifier only gives power specs as into 8ohms, is there any other spec that will tell you if it can easily power 4ohm speakers?
Post edited by crouse on
  • BlueFox
    BlueFox Posts: 15,251
    edited October 2012
    A rule of thumb is that if a spec is missing then it is not supported. 4 ohm speakers are common, and amp manufacturers know it.
    tonyb Posts: 33,072
    edited October 2012
    Which amp are we talking about exactly ?
  • George Grand
    George Grand Posts: 12,258
    edited October 2012
    BlueFox wrote: »
    Never heard that one before.
  • Blownrx7
    Blownrx7 Posts: 137
    edited October 2012
    BlueFox wrote: »
    Not supported may be a little harsh but you can bet the performance is NOT as good as you would hope. If it was, you can bet the mfr would be listing it in the specs.
    tonyb Posts: 33,072
    edited October 2012
    tonyb wrote: »
    Hate to quote myself, but untill we know this, everyones just guessing.
  • bthogan
    bthogan Posts: 151
    edited October 2012
    Maybe current capacity, or peak current capacity. It's in amperes. The higher, the better.
    Marantz CD6004
    Adcom GFP-750
    McCormack DNA-1
    Polk LSi9s
    Signal Cable ICs
    Blue Jeans cables
  • crouse
    crouse Posts: 34
    edited October 2012
    Sorry, been away from the computer. The question specifically concerns a Music Hall a15.2
  • gigbyt
    gigbyt Posts: 145
    edited October 2012
    Something with autoformers would work.
  • zingo
    zingo Posts: 11,258
    edited October 2012
    I wouldn't drive current hungry speakers with that amp as it'll overheat (LSi15), but there are many easy to drive 4 ohm speakers (Klipsch) that would be fine.
