Audio GD NFB 1.32
PrazVT
PrazVT Posts: 1,607
edited October 2012 in Going Digital
Hey Guys - hope everyone's doing well. I haven't been on here in a few months - spending time on CP tends to make me buy things & that was tough after a new car purchase - so self imposed hiatus. Now that I've sold my old car ... I can perhaps afford to feed the audio monster a little.
So, I'm pondering a new DAC for the bedroom system and I was perusing Audio GD's site. The 1.32 looks like an interesting ES9018 based DAC - has anyone used it? Thoughts?
Would be used w/ the LSi9 / NAD 375 / SB Touch (coax) and my Win 7 64 / OS X machine (via usb)
Thanks,
Praz
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups.
Post edited by PrazVT on
    edited October 2012
    Don't know about that particular model, but I have owned the NFB 3 and liked it alot. I used the coax digital input from my Sonos and it worked well. Their usb seems a tad quirky judging by reviews over at Head-fi, but if your not going to use the usb and just go from your SB to the dac by digital, you'd be pleasantly surprised at the SQ you get for the price you payed.
    EndersShadow Posts: 17,718
    edited October 2012
    tonyb wrote: »
    Eh, its the Tenor 8022 USB chip that seems to be quirky IIRC. I have the NFB-5 (uses the Tenor 7022) and am LOVING IT!
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited October 2012
    I would guess that the Sabre chip would be a good match based on the rest of your system. The Wolfson chips they use in some of their other models probably wouldn't fit in quite as well since your system is already fairly laid back. The chip obviously everything, but all else being equal the Sabre will have a mroe neutral sound vs the Wolfson chip which can be warmer.
    I think the model you're looking at would be a great choice
    heiney9 Posts: 25,492
    edited October 2012
    The NFB 3 uses the Tenor 7022 it can be really quirky at times.
    The Keces uses a Burr Brown and it's been rock solid using the ASIO4ALL plug-in.
    FWIW
    edited October 2012
    heiney9 wrote: »
    FWIW
    May be quirky but the folks with the Tenor 8022 are reporting BSOD when listening to audio in addition to other computer becoming non functional issues....
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2012
    Primarily, I'd be using coax w/ the SB Touch. But I may need the USB on the OS X side of my PC (hackintosh - can't get the onboard optical working thus far). I'll google on the USB issues.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    edited October 2012
    PrazVT wrote: »
    You might be ok as most of the USB issues I believe are with Windows 7 folks NOT mac..... there is a thread on headfi about it, look there for the info.
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2012
    Okay - good to know. I'd use optical for Windows via the SB X-Fi HD Titanium, so that shouldn't be an issue.
    So ..Assimilated's neutral / warm comment makes me think about the KEFs in the living room. While the W4S DAC-1 is a great DAC that reveals all the little details, I've found that on some recordings, it doesn't help w/ the KEFs' innate slight brightness. I've used the W4S w/ the LSi9s and it's a great combo. Perhaps a warmer DAC w/ the KEFs is in order.
    Should I be fixated on ES9018 based DACs? I will swap in the DacMagic today and see if it improves at least that aspect of it. When I bought those speakers, I just swapped DACs without comparing them. Otherwise, if you guys have any suggestions on that front, would be great.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • Systems
    Systems Posts: 14,872
    edited October 2012
    heiney9 wrote: »
    FWIW
    Dead Horse, been there done that!
    Testing
    Testing
    Testing
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2012
    Just an update ..decided to try something new - ordered a Schiit Gungnir DAC to try with the KEFs. I should get it on Wednesday and I'll start burning it in and see how it does in comparison w/ the other two DACs. Figured I'd see how the dual AKM4399 DACs do.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2012
    so the Schiit DAC arrived today. Just starting the burning in process, so can't make any definitive comments. But pre-burn, a couple of observations:
    - lots of bass!
    - the highs are not as harsh as the W4S was on day 1, which means it should only get better.
    - much closer to the W4S than DacMagic detail-wise, and smoothness in between.
    - built like a tank and weighty.
    that's it for now ..will leave this with obligatory cell phone pics...
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    edited October 2012
    Congrats man, further observations when you have time.
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2012
    I am going to start a different thread on this as the title is completely misleading at this point
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
