Pre amp question
jonicont
I'm no longer using the CD player since I got the Sqeezebox, so I'm going to can it and free up some space in the living room wall unit. I want to add a Rogue Perseus Magnum to the main in's on the integrated (see sig). I'm assuming it bypasses the pre of the integrated but want to be sure before I pull the plug.
I don't post a lot so I want to take this opportunity to thank many of you regular posters for helping me to set up a fantastic sounding system. The wealth of info here is invaluable
DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
Post edited by jonicont on
I am not understanding your question. You have the rogue preamp, you hook the squeesebox up to the rogue, rogue to your amp or are you talking about hooking the W4S dac on a fixed output to the Rogue then to the amp? Are you using the NAD as your amp and you want to bypass the preamp part of it? ( btw darn good integrated amp)Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I don't know what a Rogue Perseus Magnum is but as long as its gain (level) can be varied you should be able to bypass the integrated amp's preamp section via the amp's "main in" and "mainline" the Magnum thingy to the power amp! You will of course lose any of the preamp section's functionality (switching, monitor loops, volume control, filters or EQ, if so equipped).
Yes, if installed in the integrated's loop. Or, he could use the Rogue as a pre, and just use the NAD as a power amp.mhardy6647 wrote: »I don't know what a Rogue Perseus Magnum is but as long as its gain (level) can be varied you should be able to bypass the integrated amp's preamp section via the amp's "main in" and "mainline" the Magnum thingy to the power amp! You will of course lose any of the preamp section's functionality (switching, monitor loops, volume control, filters or EQ, if so equipped)."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
