question
oldrocker
I just bought a pair of used sds srs speakers and have a few questions about amps/preamps and tweeter replacement as 2 tweeters seem to not be working.
Post edited by oldrocker on
Try looking at the sticky's in vintage speakers. Lots of info there. I'm sure the SDA guys will be here soon to help out.
What are your questions?Political Correctness'.........defined
President of Club Polk -
I ordered a cerwin vega cv 2800 amp for these speakers, I want reccomendations for a pre-amp to run the system. I want a pre-amp with a remote control for volume control, any thoughts on a good pre-amp? All I do is listen to cd's, no need for surround sound multi channel features, just 2 channel with remote control capabilities.
For starters, send that amp back and get an amp that actually sounds good.Political Correctness'.........defined
LOL...you kill me sometimes, short and to the point no B.S.....but I love that about you.
Oldrocker, maybe narrow it down a tad. Just saying your looking for a 2 channel pre amp will result in hundreds of options. How about a budget ? Solid state or tube ? Source you will be pairing it with ? Incidently, about the amp, I tend to agree with F1nuts statement. Plenty of other amps used on the cheap will serve you better.HT SYSTEM-
lsi 9's -
Thanks for the input.
Be sure you get an amp with a common ground if you do replace your cv, or you will have more blown drivers. There are other ways to deal with a non common ground amp as you will see in the links in the vintage speaker section. As chumlie says, really great info SDA's, which series speakers do you have?
