Mount book shelf speakers on 45 degree ceiling?
FATHERFORD
FATHERFORD Posts: 9
edited September 2013 in Speakers
I have some Polk Audio TSI 200 I want to ceiling mount for my surround. I am trying to refrain from mounting on my walls as they are real wood and I'm trying to avoid creating holes.
I know a lot of guys use the Pinpoint AM-40B Side Clamping Bookshelf Speaker Mount or similar to wall mount these speakers. Is there anything for ceiling for larger book shelf speakers?
  • badchad
    badchad Posts: 348
    edited October 2012
    Omnimount has a series of ceiling mounts. I believe they go up to 30 lbs.
    I'm almost certain the image below is from a forum member here. I plan on doing the exact same thing, albeit with the mount on the wall.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • badchad
    badchad Posts: 348
    edited October 2012
    edit: sorry for the double post
    Polk Center: CSi A6
    B&K Reference 200.7
    Oppo BDP-103
  • FATHERFORD
    FATHERFORD Posts: 9
    edited October 2012
    Used the Omnimount 30.0 A little over kill for these speakers, but they work great....
    I had no idea how big the TSI 200's would look as surrounds, now I just need to buy two more for back surrounds.
  • FATHERFORD
    FATHERFORD Posts: 9
    I'm going to bump my old thread back up to try and get some suggestions...
    So I'm finally bought my rear surround, but omnimount discontinued the 30lb mounts!
    I have found Axiom Audio full metal bracket that might have to work... Anyone have any suggestions?
  • RamZet
    RamZet Posts: 792
    did you look up the omni mounts on amazon or ebay?
    B&W CM9Classé Sigma
  • Rishen
    Rishen Posts: 2
    Hi,
    I'm using a pair of TSi100's for my SR & SL.
    I'm looking to ceiling mount them as I can't use side or rear walls.
    So far I've come across:
    -PinPoint Mounts AM-25,
    -OmniMount 10W/C, &
    -OmniMount 20C.
    I've seen the BTech BT342, they're very similar to the PinPoint Mounts.
    Any advise on mounting them?
    Did you drill the speaker cabinet?
    I'm in South Africa so we're pretty limited selection wise. Therefore I want to be very certain before I commit to ordering online.
    Any advice would be greatly appreciated.
