Cs275
factorz
Looking to upgrade from my CS1 and this is one of the few Polk centers that will fit my cabinet. I'm in WI so local would be great, but shipping is good with me as well.
Post edited by factorz on
I've got a Cs400i that's for sale...huge step up IMO. I am also from Wisconsin.
http://www.polkaudio.com/forums/showthread.php?136088-Complete-older-RTi-set-up....WISCONSINPioneer SC-37
RTiA9-fronts
CSiA6-center
RT55i-surrounds
SVS PB13 Ultra & PSW650
Monster Power 3250 amp
Monster Power 2250 amp
Monster Power HDP-2500 surge pro.
Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust -
bassaholic wrote: »I've got a Cs400i that's for sale...huge step up IMO. I am also from Wisconsin.
Wish I could but its too big for my area. Needs to be no bigger then 7" -
I got a cs300 for sale will that fit ??Looking to upgrade from my CS1 and this is one of the few Polk centers that will fit my cabinet. I'm in WI so local would be great, but shipping is good with me as well.
factorz should give the dimensions again for his center channel space. On another thread of his, I'm pretty sure he said that the cs300 was too long. -
I build and sell speaker cabinets to fit matching all the cabinet volumes , for example I can change width but add volume somewhere else .
My last polk was a cs350 .teekay0007 wrote: »factorz should give the dimensions again for his center channel space. On another thread of his, I'm pretty sure he said that the cs300 was too long. -
Right now I am using the CS1 which is 7" high and 18" wide. The key spec is the height as 7" just barely fits, but I do have a little more room for the width (20"). I tried to look at the specs of the CS300 and nothing was listed.
7" tall 16 3/4 wide 11" deep , if you cant find anything that sounds good in your needed fit let me know I will build a custom cabinet for it .Right now I am using the CS1 which is 7" high and 18" wide. The key spec is the height as 7" just barely fits, but I do have a little more room for the width (20"). I tried to look at the specs of the CS300 and nothing was listed.
