Cs10
Currently I use a CS1 with my setup and thinking of upgrading to a CS10, but wonder if this is going to give me some improvements with TV viewing and movies? Thanks.
Post edited by factorz on
Not really, move up to the CS20HT SYSTEM-
lsi 9's -
or CS2 if you have other monitor series such as 70's, 60's, 50's, 40's or 30's.
CS20 if you have the TSI 100's, 200's, ect..2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer. -
My fault for not giving better info at the start. The CS20 won't work as I have size restrictions of no higher then 7" and can't be wider then 24". I will be paired with a set of RTA-12C.
Then CS2 won't work either, it's almost 8" tall....hum.
Not sure on the size of the older and hard to find CS350 vintage center channel..2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer. -
I'm running a CS10 with heavily modded RTA 12C's as my front L-R mains. It works pretty well, though I plan to upgrade the Xover on the CS10. From what I understand the drivers respond well to a cap/resistor upgrade and it should be cheap as there's only one Xover to do."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
The 350 is only 7" tall but it's 26" wide. It's a big boy.... -
ken brydson wrote: »The 350 is only 7" tall but it's 26" wide. It's a big boy....
Yeah it was one of the first one's I looked at, but the length won't work in my setup. I guess I might have to look outside Polk to find a step up. Any good suggestions to match with some vintage Polks? -
The 400 and 400i would match pretty well. They are shorter but taller. Matching vintage Polk with another manufacturer is goung to be a challenge IMO. I'd look to figure a way to make a 350 or 400 fit. The 350 had a little bro IIRC Think it was a CS 245 or something....
