APC H15 Power Condition & Portable AC
audiocr381ve
audiocr381ve Posts: 2,588
edited October 2012 in Electronics
Am I safe plugging my portable AC unit (10,000 btu) into my APC H15 power conditioner? I mean, it's plugged in now and working along with all my other devices plugged in to the H15 (computer, hard drives, etc.). When the AC compressor kicked in the line boost and the H15 turned on for a split second. Not sure what that was about or if that's a bad thing.
Post edited by audiocr381ve on
  • obieone
    obieone Posts: 5,077
    edited October 2012
    I wouldn't. The inrush of the compressor is prolly pushing the APC to it's max.
    EndersShadow Posts: 17,696
    edited October 2012
    Agreed, I wouldnt do it. If your worried about blowing up you portable AC unit, just use a standard surge protector, or if you own get a whole home surge protector installed at your breaker box. That will not replace your need for the H15 for your audio gear, but it should help with everything else.
  • rpf65
    rpf65 Posts: 2,127
    edited October 2012
    Agree with the above. Lets face it, the power conditioner probably cost more than the air conditioner, and besides has a 5 to 7 year shelf life.
