Cs10
factorz
factorz Posts: 353
edited October 2012 in Speakers
Currently I use a CS1 with my setup and thinking of upgrading to a CS10, but wonder if this is going to give me some improvements with TV viewing and movies? Thanks.
Post edited by factorz on
    tonyb Posts: 33,072
    edited October 2012
    Not really, move up to the CS20
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited October 2012
    or CS2 if you have other monitor series such as 70's, 60's, 50's, 40's or 30's.
    CS20 if you have the TSI 100's, 200's, ect..
  • factorz
    factorz Posts: 353
    edited October 2012
    My fault for not giving better info at the start. The CS20 won't work as I have size restrictions of no higher then 7" and can't be wider then 24". I will be paired with a set of RTA-12C.
  • TNHNDYMAN
    edited October 2012
    Then CS2 won't work either, it's almost 8" tall....hum.
    Not sure on the size of the older and hard to find CS350 vintage center channel..
  • drumminman
    drumminman Posts: 3,396
    edited October 2012
    factorz wrote: »
    I'm running a CS10 with heavily modded RTA 12C's as my front L-R mains. It works pretty well, though I plan to upgrade the Xover on the CS10. From what I understand the drivers respond well to a cap/resistor upgrade and it should be cheap as there's only one Xover to do.
  • ken brydson
    ken brydson Posts: 9,002
    edited October 2012
    TNHNDYMAN wrote: »
    The 350 is only 7" tall but it's 26" wide. It's a big boy....
  • factorz
    factorz Posts: 353
    edited October 2012
    Yeah it was one of the first one's I looked at, but the length won't work in my setup. I guess I might have to look outside Polk to find a step up. Any good suggestions to match with some vintage Polks?
  • ken brydson
    edited October 2012
    factorz wrote: »
    The 400 and 400i would match pretty well. They are shorter but taller. Matching vintage Polk with another manufacturer is goung to be a challenge IMO. I'd look to figure a way to make a 350 or 400 fit. The 350 had a little bro IIRC Think it was a CS 245 or something....
