Re-tubing ARC VT-100 mkII
vc69
Hey guys,
I am preparing to re-tube an ARC VT-100 mkII. The sound with the amp has steadily been going "flat" and the soundstage is not what it once was. ARC recommends replacing tubes at 2,000 hrs and I have probably exceeded that. This amp has 8 6550's and 8 6922's. I have several questions for the tube aficionados:
1)I am daunted by the options for 6550's. Are KT-88's a direct and viable replacement tube? If so, can you explain any difference between 6550's and KT-88's?
2)Do the 6922's need to be replaced at the same time, or do they last longer like preamp tubes, which have a recommended lifespan of 5,000 hrs.
3)Can you guys recommend a good brand? Gold Lion? Sovtek?
4)Is matching important when going with all new tubes? Should I have them matched in Quads or Octets? Will this affect my ability to easily bias the amp once the new tubes are installed?
This is no small expense and I would like to get it right. Of course, ARC wants to sell me their tubes but they seem a little high compared to ordering from Tube Depot, etc. I plan to talk to these folks (ARC, tube dealers, etc.) but I would like to be armed with some knowledge going in.
Thanks in advance for any help or suggestions. I look forward to hearing some advice.
-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's
Post edited by vc69 on
Buy a matched set of 6550c winged "c" tubes. Be careful, the company split
and the name went one way, the winded "c" logo went another. Go with the
wings. The 6922 tubes do last longer.
Note: the whole 2000 hour thing is really overkill. But changing tubes before
they pop and kill other stuff is a good idea. Please check the bias setting to
make sure your not a simple turn of a screwdriver away from good sound."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Thanks for the reply/info.
I biased the amp just a couple months ago, but I will revisit just to be sure.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
The great thing about arc stuff is you can run current, quality power tubes
and sound great. you can then do your fine tuning for sound using the 6922's.
Much cheaper to fool around with than NOS power tubes."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
So there is a big difference in the 6922's? I have whatever came stock in the amp. Any recommendations where those are concerned? Some of those NOS tubes are extremely expensive. Are any of the current production tubes worthy?-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
I have many quads of 6922 tubes that I was planning on putting in the Flea market soon. Usually tubes should run in pairs (one for each channel), so I assume that if you need eight tubes, four pairs or two quads should work well. PM me if you are interested.
The Gold Lion tubes are great, but are more detailed than warm if that works with your system. The best new tubes for that variant in my opinion, but not cheap. -
That depends on what you thought of the sound up to now.
If you liked it, stick with the same. Warmer, detailed, etc. are changable.
A quick run over to tube depot or others, read up, and then search here by
brand/series to pick one. Warning: this is normally the start of the "tube stash"
that keeps growing in back of your closet."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
If you decide to look at the KT88 tubes the KT88sc is marketed through Penta Labs (Doug's Tubes sells them as well as others). These solid plate tubes are what performs best in my VAC amps IMO.
Rickintegrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
Thanks Rick, and everyone else that has replied. I have tracked down a connection to a guy that works for ARC and as soon as I get some info from him, I will pass it on here. I am anxious to hear what those guys have to say regarding tubes recommendations, matching, brands, etc.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's
