Wire gauge and length
I apologize! I have the answer for the length and gauge question, I'm sorry that wasn't clear. I don't always make things clear when I'm typing out thoughts. I'm talking about "Material and the quality of it, solid, stranded or both, configuration, dielectric and termination" to quote F1. What do these mean?AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it -
I already explained the terms in post #27.Political Correctness'.........defined
President of Club Polk -
I am not telling you what to get only what I got and it seems to work well, ok for me.
My surrounds rear are polk monitor series 2 70's.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023902&p_id=2819&seq=1&format=2
It says in wall but I use it under the carpet
Now I do have Kimber cables on the fronts 2.3tlsPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Fair enough....
Material and the quality of it - common choices are copper, tinned copper, silver clad copper, silver. The purity of the material and the drawing process also play a role.
Solid, stranded or both - wire can be solid core, stranded or a combination of both.
Configuration - can be twisted, straight, larger gauge combined with smaller gauge and a whole bunch of other variations.
Dielectric - the material used around the wire, lots of choices.
Termination - the type of end (banana, spade, etc.) attached to the wire, which can be soldered, crimped, a combination of both, cold welded, even just bare wire ends.
F1, apologies bro! I didn't see this post reply come through my notifications!! My fault! Thanks for the good info!AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
