How many watts amp for party
JustinChiu24
Say I'm using Tsi100's for a party, how many watts should the amp be to be loud enough to fill a 25*25 m space?
Post edited by JustinChiu24 on
That is 15,625 cubic feet. The square root of that is 125, so in order to have some reserve, it appears 200w/channel is required.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
wow, that's quite a lot of power. Doesn't the speaker efficiency effect the calculation?
They are 8 ohm 89dB bookshelf speakers. They should be fairly easy to drive. What electronics do you currently have to drive them with or are you looking to buy something. I wouldn't spend too much on electronics given the speakers only cost $219 new. Let me know if you need suggestionsRig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4 -
I'm looking at the Pioneer A-20 or Onkyo M-282. If I have enough cash left I might consider changing the TSi100's for RTiA1
It'll be great if you can give me some suggestions, I'm looking for a 2 channel amp, with atleast 60W per channel -
I did the math wrong (darn beer). I used 25 as the height for the cubic feet. However, ceilings are usually 8 feet high, and that results in 5000 cubic feet. The square root of that is 70. Throw in some reserve and you have a minimum of 100w/ch. However, if the speakers only cost $219 a pair, I suspect you might find it difficult to be "loud enough" for a party no matter how much power you have.Lumin X1 file player, Westminster Labs interconnect cable
Oh I see, so you're suggesting that I look for some higher efficiency speakers?
JustinChiu24 wrote: »Oh I see, so you're suggesting that I look for some higher efficiency speakers?
No, not really. Efficiency is certainly useful, but isn't the only, or primary, quality in speakers. First, I was kidding with the math, but the results are reasonable. Go figure. Anyway, I might be wrong, but I suspect if the electronics are up to par then the speakers might start to breakup while trying to be loud in that space. This is only a guess, but I bet the TSI100s are great for an office, or other small room, while not quite there for loud levels in a bigger room.Lumin X1 file player, Westminster Labs interconnect cable
Okay then, thanks for your feedback
I'll do some math for ya.
Big room + small speakers + very loud volume = buying new speakers after those get toasted.
Thats a pretty big room and to fill it with sound at the levels your suggesting isn't going to end well with those speakers. Buy something made for the abuse like Cerwin Vega or even Klipsch. Better yet, look on your local craigslist for a 50 buck pair of tower speakers, blast them to all hell for the party, if they survive keep 'em around, if not oh well.HT SYSTEM-
lsi 9's -
yeah, I just passed on a set of Klipsch F2' and sub 10 for 200 bucks so disposable towers are to be had!! depends on disposable income!!??:razz:I'll do some math for ya.
Thats a pretty big room and to fill it with sound at the levels your suggesting isn't going to end well with those speakers. Buy something made for the abuse like Cerwin Vega or even Klipsch. Better yet, look on your local craigslist for a 50 buck pair of tower speakers, blast them to all hell for the party, if they survive keep 'em around, if not oh well."if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
If u can find a pair of monitor 12's... Great party speakers can be played loud but do need a bit of power suggust 200 watts high currant. And everyone will leave the party deft.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Also " for a party" run amp in mono if u can" as it will sound full in any location in the room. ( wont have to be in the opt listening possition.)Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
soundfreak1 wrote: »If u can find a pair of monitor 12's... Great party speakers can be played loud but do need a bit of power suggust 200 watts high currant. And everyone will leave the party deft.
What??:razz:"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
i would love to leave a party more capable than when i arrived....:cool:Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
a inexpensive amp plenty of power and reliability is a kenwood km208 , I bought 2 for $50 on ebay
Make that DEAF (fat thumbs tiny keyboard)Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Math is wrong, you're looking at roughly 52812.5 cu.ft with an 8 ft ceiling. that was a 25 x 25 meter room, not foot.
That...is actually a pretty large room for a pair of tsi100's...... lolHT: M5510-Prox2/PN51E550/NR708/M282(3)/RTi A7/CSi A6/FXi A6/DSWPro660x2/PS3/HTPC
Office: Belkin PF60/PN43E450/Marantz 1501/PSB 400/Image C4/WD Live TV
2-Channel: Yamaha C4/M4(2)/DQ-10's/DQ-1w(2)/SBT/Pioneer R2Rl/Technics SL-7/AR EB101
Desk: QSC RMX850/Behringer B2030P -
For party speakers, you want large displacement drivers for the combo of high volume and punch. Can someone say Cerwin Vega!?!
