Noob To Forums & Mids To Home Audio...
GatorBaitCpl
This is my first post here some please don't destroy me just yet...
I am putting together plans for a 2 Channel system that will be used in a very large rec room. I want to go with RTi A9's and bi-amp both speakers. I would also like to be able to run a Record Player, SACD, iPod, and Stream in Pandora as well. My budget for Pre-Amps, Amps, and the rest will be around $2000-$3000. I am certainly not opposed to using quality used products as well. My main questions here are what watts would you run for the lower and uppers on the RTi's and I am very interested in using Rotel amps and pre-amps and wonder if you can suggest other brands I should look at. I would also love any other info I may be forgetting here as well...
Thanks in advance for any info...
Gator
Gator
Post edited by GatorBaitCpl on
Welcome to Club Polk! Sounds like you will have some fun putting your system together. You might consider one of the Sunfire 2 channel amps and preamps. Keep us posted on your progress.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Bi-amping without using active crossovers is a waste of time and money. You're better off getting a really good stereo amp or mono blocks and using high quality jumpers on the binding posts.Political Correctness'.........defined
President of Club Polk -
+1 to F1. Spend your efforts elsewhere.also for the price of rotels u can look at aome B&K, parasound, and many othert with better price to spec values. Jmho.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Why the RTi line? They are designed for theater, the Lsi line, particularly the LsiM are the 2-channel speaker.
Start with the speaker, then build the gear around the rig.
RT1 -
Welcome to Club Polk.
I think you should go with either LSIs or the LSIm for speakers. Keep in mind these are 4ohms speakers so the more power you give them the better they will sound. Rotel makes terrific gear, I will always have a Rotel piece in my system. Stalk www.audiogon.com for great deals on the electronics. You can also look at Sunfire, Parasound, B & K gear while you are there.
Keep us posted as you put your system together.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I would agree with F1. Bi-amping the speakers is pretty much a waste of money. Your choice of the RTi 9's, altho nothing wrong with them, there not as "accurate" for 2 channel stereo music as the LSi line. It would depend on what your end goal is for your large rec room.
Welcome to polk audio forums:cool:
