Noob To Forums & Mids To Home Audio...
GatorBaitCpl
GatorBaitCpl Posts: 1
edited October 2012 in 2 Channel Audio
This is my first post here some please don't destroy me just yet...
I am putting together plans for a 2 Channel system that will be used in a very large rec room. I want to go with RTi A9's and bi-amp both speakers. I would also like to be able to run a Record Player, SACD, iPod, and Stream in Pandora as well. My budget for Pre-Amps, Amps, and the rest will be around $2000-$3000. I am certainly not opposed to using quality used products as well. My main questions here are what watts would you run for the lower and uppers on the RTi's and I am very interested in using Rotel amps and pre-amps and wonder if you can suggest other brands I should look at. I would also love any other info I may be forgetting here as well...
Thanks in advance for any info...
Gator
Post edited by GatorBaitCpl on
  • helipilotdoug
    helipilotdoug Posts: 1,229
    edited September 2012
    Welcome to Club Polk! Sounds like you will have some fun putting your system together. You might consider one of the Sunfire 2 channel amps and preamps. Keep us posted on your progress.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
    F1nut Posts: 50,836
    Bi-amping without using active crossovers is a waste of time and money. You're better off getting a really good stereo amp or mono blocks and using high quality jumpers on the binding posts.
  • soundfreak1
    soundfreak1 Posts: 3,414
    +1 to F1. Spend your efforts elsewhere.also for the price of rotels u can look at aome B&K, parasound, and many othert with better price to spec values. Jmho.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Why the RTi line? They are designed for theater, the Lsi line, particularly the LsiM are the 2-channel speaker.
    Start with the speaker, then build the gear around the rig.
    RT1
  • cfrizz
    cfrizz Posts: 13,415
    Welcome to Club Polk.
    I think you should go with either LSIs or the LSIm for speakers. Keep in mind these are 4ohms speakers so the more power you give them the better they will sound. Rotel makes terrific gear, I will always have a Rotel piece in my system. Stalk www.audiogon.com for great deals on the electronics. You can also look at Sunfire, Parasound, B & K gear while you are there.
    Keep us posted as you put your system together.
  • naturallight
    naturallight Posts: 689
    I would agree with F1. Bi-amping the speakers is pretty much a waste of money. Your choice of the RTi 9's, altho nothing wrong with them, there not as "accurate" for 2 channel stereo music as the LSi line. It would depend on what your end goal is for your large rec room.
  • gigbyt
    gigbyt Posts: 145
    edited October 2012
    Welcome to polk audio forums:cool:
