Riding Gear?
  • ratster
    ratster Posts: 324
    edited September 2012
    I wear a onesy,Teiz Lombard and Held gloves.
    The 300 should be a fun.
    Riding slow bikes fast is a lot more fun than riding fast bikes slow.
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Clear Day dbl.shotgun
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
    Clear day dbl shotgun
  • PerfectCreature
    PerfectCreature Posts: 1,456
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • ViperZ
    ViperZ Posts: 2,046
    It's a very 'no frills' jacket. Most likely it will be very cold riding in this jacket very soon. And remember that nothing is better for crashing (abrasion) than leather.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • PerfectCreature
    Okay, care to make a suggestion?
    I am not really sure what would make the better jacket. I saw it had the armour and good reviews, so I figured it should be a good one.
    I am open to any ones you want to select out?
    Thanks.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • exalted512
    exalted512 Posts: 10,734
    If you do get it, grab the back protector with it
    "(CE-certified RC Back Protector available as accessory)"
    -Cody
  • PerfectCreature
    I am picking it up "used" they wore it once, didn't fit.
    They do not have the back protector I just asked.
    The back protector is about $30 from the website that no longer has the jacket.
    Are there any other options that someone would like to recommend, or that they know is a quality jacket from experience?
    Thanks. $200 or so is my price range.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • ViperZ
    ViperZ Posts: 2,046
    My opinion is obviously biased, but check this one out:
    http://www.motorcycle-superstore.com/14/67/906/32975/ITEM/Scorpion-Tornado-Jacket.aspx
    In addition to a bunch of safety features, it has good ventilation and extra layer (liner) inside. I'm not a velcro fan, would rather have zippers, so that's a minor negative.
    You can even get a brand-name leather jacket if you go up to 250:
    http://www.motorcycle-superstore.com/14/67/906/10448/ITEM/Alpinestars-Rod-Leather-Jacket.aspx
    But you're on the right track. If you're willing to go a used route, you can score a really good almost new jacket or pants for like 1/3 of the actual price. I just bought a decent pair of perforated leather Teknic pants for 80 bucks. Not the greatest deal, but in Canada those retailed for 180+tax or more.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • PerfectCreature
    I do like the Scopion jacket.
    He is offering me a helmet and the jacket for $140 shipped. The helmet needs a new clip for the visor.
    Here is the Flicker profile that shows the photos of the helmet and jacket.
    http://m.flickr.com/#/photos/87046498@N03/
    Any observations?
    He is offering the jacket at $80 plus shipping. I am sure if I offered $90 shipped he'd take it though.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • exalted512
    I'm very weary of buying used helmets. I think the jacket is fine, just pick up the back protector that fits in it.
    -Cody
  • ViperZ
    ViperZ Posts: 2,046
    exalted512 wrote: »
    -Cody
    What Cody said. Do not buy a used helmet. If you're on a budget, you can always find a decent DOT-approved brand new helmet from a cheaper brand - HJC, Zox, etc.
    Also, it's the end of the season anyway. I'm sure you can find something better and local. I'd be vary about buying any gear without trying it on first. It may be your favorite color and "your" size, but you might hate it when you'll try it on.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • PerfectCreature
    I will have to do some local research I guess then. I am not really fond of the jacket as much as I thought.
    I think I will have to see if I have any shops that support the street bike community, thought the ones I know of are strictly harley.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
