ADCOM GFA-555 amp
laotzu61
laotzu61 Posts: 327
edited October 2012 in Electronics
i have an opportunity to pick up a mint adcom gfa-555 power amp to drive my polk rta-12b's. would i be able to use my kenwood kr-5600 as a preamp (with the jumpers in the rear removed) until i can get a deticated preamp? thanks.
"The symbol is not the reality"
Post edited by laotzu61 on
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited September 2012
    If those are pre outs? Yes.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • laotzu61
    laotzu61 Posts: 327
    are pre outs the same as line outs? (learning curve here!!) if i remove the jumpers, i effectively remove the tuner section, from what i understand.
  • littlewoodboats
    littlewoodboats Posts: 823
    Look at the jumpers. They should say Pre out and main in. If you remove the jumper you decouple the amp. (my Yamaha has a switch) Go from the pre out side of the jumpered connections to your outside amp and all will be well.
    I am doing this in reverse with an Adcom pre to a Yamaha integrated Amp running decoupled.
    Your amp is one that can be separated for function. The jumpers tie the pre to the amp. Remove the jumper and use either section independently at your will.
  • laotzu61
    laotzu61 Posts: 327
    thankyou. i will be playing with my stuff tomorrow, as i got my new speaker cables today. any recomendations on a dedicated preamp for the future? (under $500.00 used or new) also hooking up a dynaco equalizer i picked up.
  • polkrt3000p
    polkrt3000p Posts: 146
    edited October 2012
    I have used Adcom GTP-450 and GTP-500 and had good results. They can be had for for around 200 used. I use a Pioneer C-72 Preamp and very happy with. I think you can find a nice denon or yammy preamp reasonal priced. I use a Sunfire Preamp on my main rig.
