ADCOM GFA-555 amp
laotzu61
i have an opportunity to pick up a mint adcom gfa-555 power amp to drive my polk rta-12b's. would i be able to use my kenwood kr-5600 as a preamp (with the jumpers in the rear removed) until i can get a deticated preamp? thanks.
"The symbol is not the reality"
Post edited by laotzu61 on
If those are pre outs? Yes.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
are pre outs the same as line outs? (learning curve here!!) if i remove the jumpers, i effectively remove the tuner section, from what i understand."The symbol is not the reality"
Look at the jumpers. They should say Pre out and main in. If you remove the jumper you decouple the amp. (my Yamaha has a switch) Go from the pre out side of the jumpered connections to your outside amp and all will be well.
I am doing this in reverse with an Adcom pre to a Yamaha integrated Amp running decoupled.
Your amp is one that can be separated for function. The jumpers tie the pre to the amp. Remove the jumper and use either section independently at your will. -
thankyou. i will be playing with my stuff tomorrow, as i got my new speaker cables today. any recomendations on a dedicated preamp for the future? (under $500.00 used or new) also hooking up a dynaco equalizer i picked up."The symbol is not the reality"
I have used Adcom GTP-450 and GTP-500 and had good results. They can be had for for around 200 used. I use a Pioneer C-72 Preamp and very happy with. I think you can find a nice denon or yammy preamp reasonal priced. I use a Sunfire Preamp on my main rig.
