hockey pucks!?
  • shadowlight
    shadowlight Posts: 327
    edited September 2012
    Here is a similar product from Mapleshade which will set you back $24 for 4 :eek: v/s Pexsupply where a box of 48 will cost you 13 + shipping. You can also buy them individually for 30cents per pad. For me it was worth trying the cheaper pexsupply ones. If they work great if not not a huge loss.
    pitdogg2 Posts: 26,960
    BlueFox wrote: »
    While that part is true, fidelity is directly affected by vibration. Micro vibration created internally by the electronics, and vibration by the sound pressure of the music on the rack and gear. For maximum fidelity, this vibration needs to eliminated, or minimized.
    Thanks Bluefox
    I went brain dead trying to put into words so clipdat would understand the whole picture.
    Clipdat Posts: 13,087
    :rolleyes:
  • hochpt21
    hochpt21 Posts: 5,423
    Thanks pitdogg2 and shadowlight. Maybe I'll try el-cheapos first.
    Those ginko clouds at AA look pretty sweet, but don't think I can drop $300-$500 on an isolation platform right now :wink:
  • Systems
    Systems Posts: 14,873
    No matter what you use, they are better than pucking nothing!
    Personally, I like the suspension, spike route.
    Not all solutions work as advertised.
    I would recommend trying several different approaches and see what works best for your situation.
    I tried several approaches over the last few years, and suspension on the pre, platform with spikes on the CDP and amp on its own feet on a flat surface was the magic combination for me.
    YMMV.
    Testing
    Testing
    Testing
