hockey pucks!?
sda2mike
sda2mike Posts: 3,131
edited September 2012 in The Clubhouse
anyone use these on their systems? speakers, amps, sources?
Post edited by sda2mike on
    mhardy6647 Posts: 35,040
    They make pretty good decoupling feet under a component (e.g., turntable) or speakers.
    They can also be adapted for use as record clamps :-)
    http://www.polkaudio.com/forums/showthread.php?136200-Clamp-or-no-Clamp
    Best of all, they are cheap. I have a box full that I picked up from the "yankee swap" pile at our town dump a while back...
  • ViperZ
    ViperZ Posts: 2,046
    I use a couple under the couch... lost one of the couch feet while moving... work just fine!
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • BlueFox
    BlueFox Posts: 15,251
    Not this year, there is a lockout.
    BlueFox wrote: »
    Ding, ding, ding! We have a winner!
    So... either hockey pucks'll be very cheap, or they'll be very expensive this season. Is there a Lundberg Letter for hockey puck price futures?
    Did someone just ask if we were all "hockey pucks"?
    Don Rickles: Frustrated by a lack of acting work, Rickles began doing stand-up comedy. He became known as an insult comedian by responding to his hecklers. The audience enjoyed these insults more than his prepared material, and he incorporated them into his act. When he began his career in the early 1950s he started calling ill-mannered members of the audience a "hockey puck".[10] WIKI
    cnh
  • BlueFox
    Or as Rodney Dangerfield said "I went to a fight, and a hockey game broke out."
    Clipdat Posts: 13,095
    Why is anti-vibration important? Shouldn't the equipment be able to perform adequately as long as it is not on a semi-nice rack/stand and not a wobbly bookshelf?
  • Systems
    Systems Posts: 14,873
    Raquetball halves work pretty well under source components, provided you can cut them in half accurately.
    A sharp exacto knife works pretty well.
    Testing
    Testing
    Testing
  • BlueFox
    Clipdat wrote: »
    Nope. Anti-vibration is as important as good cables. Of course you need to start with a solid rack, and go from there. I added Mapleshade Micropoint brass footers under all my gear. As it was added to each piece the sound got better and better. One of my better upgrades I must say.
    http://shop.mapleshadestore.com/prodinfo.asp?number=MPHFSET
    Toolfan66 Posts: 18,067
    Clipdat wrote: »
    Why is not shaking a baby important? Shouldn't the baby be able to handle and perform adequately as long as its not being tossed off a building.
  • sda2mike
    check toolfan66(6)'s location :)
  • sda2mike
    i asked the question about pucks because they're cheap and so am i...also, i was thinking about moving my amp into my rack..that would make the i/c run 2 ft instead of 8 ft...but, the amp would be placed in the rack right next to my right 2btl..
  • shadowlight
    shadowlight Posts: 327
    Sorry, forgot to mention that the friend used to use hockey pucks before he transitioned to the vibration pads and his comment was the improvement was for the better. I am still building my rack and will get to try it out next week.
  • sda2mike
    those have a good look..thanks
  • sda2mike
    i was thinking on my 2btl's, i have spikes, but because my floors are 'bumpy' tile, i dont have the discs under the spikes..i was thinking of taking a puck, putting a slider under it..then i'll put the disc in the middle...either glued or set in...
    So what about when the wife starts dancing near the equipment rack and causes vibrations to travel into the equipment? Will my sonic bliss be ruined? Should I enforce a firm "no dancing" rule when listening to music?
    Toolfan66 wrote: »
  • shadowlight
    sda2mike wrote: »
    They look good and are cheap :cheesygrin:
  • steveinaz
    steveinaz Posts: 19,545
    I use 3 hockey pucks under my BR player to raise it a bit, because my cabinet door trim blocks the remote from working.
  • dkr919
    dkr919 Posts: 379
    Oh never mind. I misread the thread title and was chiming in to agree... hockey sucks:confused:
  • hochpt21
    hochpt21 Posts: 5,423
    I wonder if these would work under my TT? It is currently on top of a heavy wooden equipment rack, but there is no vibration control. The TT skips if my son is walking (running:cheesygrin:) around. I know the wall mounted units are supposed to be much better, but that is not an option currently.
    Edit..."These" meaning those pexsupply pads.
  • steveinaz
    I doubt they'd work in that application, pucks are pretty hard/stiff rubber.
  • hochpt21
    You mean pucks woulnd't work...or the pexsupply pads that shadowlight mentioned wouldn't work...or neither would work.
  • steveinaz
    pucks.
    pitdogg2 Posts: 27,058
    hochpt21 wrote: »
    I feel these would work much better
    http://www.audioadvisor.com/prodinfo.asp?number=PGPICO
    there are two sizes depending on the weight of the item. I've used audioquest sorbothane big feet under my CD player i could body slam someone in the room and it wouldn't skip. Since HCM was told to quit selling the big feet in bulk for nickles on the dollar compared to 30.00 ea that Audioquest charges.
    I bought a set of 4 for 50.00 when they sold them. These are the next best thing IMHO
    So can someone seriously address my question re: dancing? I am honestly curious, not trying to be sarcastic.
    Clipdat wrote: »
    see post 22 that is one very good reason. some cheaply made stands can induce a hum also if pick up by sensitive equipment and CD players can be very skippy on some floors when pets or people walk near the rack.
    so addressed CLIPDAT....
    Oh ok, so it's in regards to physical needle/stylus or laser pickup skipping, not directly related to fidelity or quality of audio. Got it.
  • shadowlight
    hochpt21 wrote: »
    Yep, they will work. I will find out from my friend what else he puts those under I know he has them under TT and CD player but not sure about other equipment. Meeting up with him tomorrow.
  • BlueFox
    Clipdat wrote: »
    While that part is true, fidelity is directly affected by vibration. Micro vibration created internally by the electronics, and vibration by the sound pressure of the music on the rack and gear. For maximum fidelity, this vibration needs to eliminated, or minimized.
