Wisdom Teeth
VR3
WISDOM TEETH...........SUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Man, it started coming in about 2 weeks ago (only one), and about 2-3 days ago my entire left side of my face basically swelled up to the point my face felt like a brick........
So then I get some of this Orajel stuff to put on it till I go to the dentist this thursday.......
the swelling has gone down, but my jaw feels like...........its there........but its not. It hurts, but it dont.......
BLAH
Eff Wisom Teeth and the horse they road in on!!!!!!!
:eek:
BLAH
:eek:
Been there, but mine didn't bother me till I was 24.
I feel for ya it does suck!!!!!
Dave -
Sid,
Wisdom teeth troubles at 15???
you need to stop hanging out on this board so much;)
All this schooling is getting to ya!!
Seriously though, hope the dentist takes care of it. Thursday?? Man is there a shortage of dentists where you live bud? That's quite a while to live through that torture.
PJ. -
Well honestly.....
I can't 'feel' any pain - its just that my entire left jaw is swollen pretty good....
and the medicine I have to put on it.......I'm not sure if it 'helped' me or made it worse....
Dunno......- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I lucked out bigtime! My wisdom teeth didn't cause any problems.
Good luck Sid!
JohnNo excuses! -
Rinse with 1/2 water and 1/2 hydrogen peroxide every 4 hours or so. Take over the counter Ibuprofen and call your dentist or primary care physician either today (most have an on call emergency number) or tommorow morning and decribe your symptoms. If your swelling continues and you can't reach anyone go to the ER.Receiver = Denon AVR-3803
DVD = Denon DV-2900
Fronts = SDA SRS 2.3TL's
(Carver m1.5t)
Center = CSi40
Side surrounds = Fxi30's
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Pioneer SX-1050 receiver
Rti38's -
I was gonna say swish with whiskey and chase with a beer every hour as needed, then is the morning take the Ibuprofen when its really needed
Life without music would♭ -
No surprise here......My mouth is big enough to accomodate all 4 wisdom teeth without any problems....;)comment comment comment comment. bitchy.
yuck
Sorry you're having a hard time of it. It seems I made out easy. All 4 of mine were impacted, I just had them all removed at 20 to save myself the pain of having them pulled one by one when they would've gotten infected and would have to be taken out anyway.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
All four of mine were yanked out at one time a few years ago. My dentist said I didn't need them anyway, but I wasn't foolish enough to believe her.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Luckily, my DNA evolved and I only had 2 wisdom teeth (uppers). Had 'em pulled quite a few years back.
Enjoy! -
I rinsed my mouth out, swished out - etc with Salt Water.....
and I looked up what to do on the internet, and they said to brush the best you could in the area.
Best they described was this.....
The flap above the tooth becomes inflamed (mine hasnt), as decay get down between the tooth ---
My tooth, is ramming against my other tooth, basically......
I am using Orajel which has pretty much lessened the swelling down to my jaw area, which dosnt really hurt.....it just feels big....
I am calling the Dentist tommorow, and hopefully I can go alot sooner than Thursday to get this taken care of or looked at.
Here is what I think is wrong ---
The tooth is coming in where my mouth connects'' I guess you could call it that, to my jaw. The tooth 'erupted' right where the mouth and gum meet.
I dunno, not very fun........- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It's sounds like pericoronitis. It happens when there is a flap of tissue partially covering your tooth that becomes traumatized when you bite it during normal chewing, talking, etc.. Swelling, elevated temperature and a feeling of "hardness" in the affected area are possible signs of an infection. Hydrogen peroxide rinse will help to cleanse the area until you get proper treatment. Good luck and definitely get seen by someone tommorow!Receiver = Denon AVR-3803
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's -
Thank you for the advice.
I rinsed my mouth out with salt water, then some very strong mouth wash that burned like crazy!!!!!!!
I brushed the area as well as I could, I took some Ibuprofen --
The swelling has gone down ALOT considering where it was at a day ago. Much more contained......
and not to mention my dental higene probally went up 50 points. lol
Im calling the dentist tommorow, hopefully they will tell me what to do....
Thanks for all the help- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
acdds, are you AC, D.D.S.? Just curious.
Ouch!:eek: Do you brush up against the gums or from the gums down? Underneath the gum line your teeth are extremely sensitive and when you brush up against the gums, it lifts it up slightly over time so the sensitive part of your teeth will be exposed. Also, when brushing against the gum (starting from teeth) you get a lot of junk between your gums and teeth which could cause an infection. It could be gum disease. Don't think wisdom teeth can make your face swell. I know someone who had gum disease and his cheeks swelled up. I was actually close to getting gum disease because of my brushing techniques so the dentist told me not to brush against the gums and gave me Sensodine toothpaste because one tooth got pretty sensitive due to the exposed part of my tooth. It's now my favorite toothpaste:).
A tip would be to use mouth wash after brushing to destroy any leftover bacteria the toothbrush missed and not skimp on regular check ups. Just thought I'd share my dentist's brushing technique with you:).
Maurice -
Shizelbs, No I just had the same thing happen to me multiple times when my wisdom teeth were erupting. It is a real pain in the a@@!!Receiver = Denon AVR-3803
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's -
I still have all 4.
Good luck with the dentist Sid.If...
Ron loves a film = don't even rent. -
The dentist gave me some medicine that fights infection ---
My jaw is stiff.....
there isnt any inflamation on my gums, atleast they're not red in anyway.....
I am rinsing my mouth out with salt water.........mouth wash.......and using orajel......etc
Doing all i can till i can go to the dentist!
There isnt really any pain that bothers me.........
Thanks for all the help - hopefully my others ones wont come in like this, maybe they wont come in at all.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'm with the rest of the huge heads here, all 4 still in my mouth. Maybe we should start our own forum. I can see it now: http://clubpolk.polkaudio.com/forum/homohabilis
Anyway people with all their wisdom teeth are special, my mom told me so.
Good luck SidThere are two ways to argue with women. Both of them are wrong. -
Had three of mine yanked out as an adult, YOUCH!! Painful, each and every one. One still remains because its roots are lodged in my sinus cavity!
My daughter had hers cut out last year, at the age of 12, because if they came in they would have caused her to have to wear braces. The surgery was much less expensive than braces! She was a real trooper about the whole thing! Even though it hurt, she could realize the benefit. She has pretty, straight teeth now! And I'm out less $$!:DBob R in OKC
Front: RTi8
Center: CSi3
Surrounds: RTi4
Sub: Velodyne CHT 10
Receiver: Onkyo TX-SR701 -
Hi:
I'm 61 and still have three of mine, that's why i'm so smart.
I had to have one removed a few years back because it was crooked, not bad.
Gary
