WASAPI vs ASIO4ALL/Kernel Streaming
blehmbo
blehmbo Posts: 179
edited November 2012 in Going Digital
Has anyone tried both WASAPI and ASIO4ALL/Kernel Streaming and noticed a difference? I switched from kernel streaming to WASAPI a few days ago, to make switching between my DAC (music) and AVR (movies) more simple while using JRiver, and I noticed a difference. I understand that they are both supposed to be bit-perfect, but I have been hearing a decrease in depth and slightly harsher high frequencies after switching over to WASAPI. I'm not sure if it's me or if either modes is doing something funny to the signal.
I'm using Win7 64bit, JRiver MC17, Wyred 4 Sound DAC2 (thanks Neil!) connected by asynch USB, Intel Core i5-750, 4GB RAM. My settings in JRiver have the buffer size for both WASAPI and kernel streaming set to 0.50 seconds, DSP settings off, and play files from memory is enabled.
  • erniejade
    erniejade Posts: 6,327
    edited September 2012
    I will have to change mine and check it out. I am also using jriver, w4s dac2 via wasapi. I have never tried anything else but wasapi on it. So you are saying asio4 sounded better yes? Later on today I will change mine out and see I can tell the difference.
  • erniejade
    aso did sound different better to me
  • blehmbo
    blehmbo Posts: 179
    erniejade wrote: »
    Yes, ASIO4ALL sounded better to me than WASPI. ASIO4ALL is essentially a hack for kernel streaming if I remember correctly, so it should sound very similar if not identical to KS. Thanks for trying it out and sharing your findings. Are you connected through your sound card or USB?
    Has anyone else had a similar or different experience with the different output modes?
  • erniejade
    asynchronous usb from my laptop running Jriver to a w4s dac2. I am using legacy focus speakers and I head the differece right away. It was not subtle to me.
  • nspindel
    nspindel Posts: 5,343
    blehmbo wrote: »
    ...Wyred 4 Sound DAC2 (thanks Neil!)...
    You're welcome!
    But I must say, reading threads like this makes me love my Squeezebox Touch. I used to use a pc as my source, but fiddling with this type of stuff really got on my nerves...
  • Shike
    Shike Posts: 12
    Last I remember ASIO was a wrapper and not necessarily bit-perfect, whereas WASAPI definitely is when setup correctly . . . could be mistaken though'.
    heiney9 Posts: 25,702
    I use ASIO4ALL and it sounds great. It also has A LOT to do with the recieving chip on the dac end. I could never get the WASAPI interphase to load without issues. Granted, I didn't try very long since I was happy with ASIO4ALL. Although ASIO4ALL freezes up frequently when I'm using the Audio GD NFB-3 with the Tenor receiving chip. With my Keces and the Burr Brown receiving chip, I don't have those issues. I use Media Monkey as the player.
    Shike wrote: »
    ASIO is bit perfect.
  • bikerboy
    bikerboy Posts: 1,242
    I thought win 7 uses wasapi and xp used asio.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
    EndersShadow Posts: 17,757
    bikerboy wrote: »
    Nope, I use ASIO in Win 7 too.
    bikerboy wrote: »
    No. It's essentially a plug in type driver for whatever program you use as a music player to interphase with external hardware (ie; a dac). The both work on Windows 7, not sure if they are both backward compatible with XP.
    http://en.wikipedia.org/wiki/Audio_Stream_Input/Output
    WASAPI is a Windows application, which first appeared in VISTA, that can provide direct unmixed audio streams but while it seems to have more functions for multi channel audio, it's more complicated.
    http://en.wikipedia.org/wiki/Technical_features_new_to_Windows_Vista
    bikerboy wrote: »
    Actually in respect to when they appeared you are correct. ASIO was used in versions of Windows prior to VISTA. WASAPI was introduced in VISTA but both can be utilized on W7 and I assume W8, unless Microsoft has come up with something else for W8.
