SDA Tweeter Brackets for SDA SRS 1.2TL, SDA SRS and SDA CRS+
How does the Moretite hold up over time? Does it dry out over time and require replacing?
OK. I'm petty obsessive. Maybe not as much as DarqueKnight, but I have a half-dozen or so Dremel tools and have used them for many, many purposes. Ready to use them as necessary to custom-fit Larry's extraordinary rings once I'm able to get my hands on a set! Thanks to everyone on this extraordinary forum!
Where can I buy the tweeter brackets and driver rings?
They were made a few years ago by forum member Toolfan66. He might have some on hand or he might make you a set...if his busy schedule permits.Proud and loyal citizen of the Digital Domain and Solid State Country!
