Recommendation: in-wall wire
shopdog328
Looking for a suggestion on reasonably priced in wall speaker wire. Only have 50 feet or so to run. It will be for the C/L/R speakers. Wall mounted around the tv
Thanks.
Thanks.
Post edited by shopdog328 on
I used this from Monoprice when I finished my basement. I got the full 500' roll.
I would go with monoprice or blue jean cables
I used Monoprice 12AWG CL2 cable for my in-wall installation. For me, it works well for HT purposes.
Currently using Belden 5000UE in-wall to my rear channels with no complaints (purchased from Blue Jeans)
Same here.Things work out best for those who make the best of the way things work out.-John Wooden -
Use the same, love it.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I would recommend Audioquest speaker wire. You can buy it from Crutchfield. Excellant cable from an excellant on-line retailer.
Here is a link http://www.crutchfield.com/p_70314250/AudioQuest-FLX-14-2-14-Gauge-2-Conductor-In-Wall-Speaker-Cable-50-feet.html?tp=2906. This is the wire I use to connect my outdoor speakers (long runs) with great results. It also gets great reviews.Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4 -
The Furez 14/2 speaker cable is a very good cable for your inwall project. It's CL3 rated, and very flexible, plus is 99.997% OFC.
http://www.douglasconnection.com/Furez-14AWG-2-Conductor-Speaker-Cable-Raw-FZ142.htmSunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Monoprice CL2 rated wire here. Cheap and does the job well.Living Room:
Paradigm Cinema 330 x 3, Pioneer 9040TXH
Media Room:
RTi12, CSi5, F/Xi3, RTi4, Onkyo SR805, SVS PB12 Plus/2, HSU MBM
