Sda compact crossover problem
bulldogfish
Iam new at working on speakers.One mid and tweeter are not working on each. I have tested the woofer and tweeter on each speaker and they work.I believe the top crossover is the problem on each speaker.Do I need to replace all caps and the resister? Any advice would be great.This model has 2 mids and 2 tweeter and the passive woofer.
Post edited by bulldogfish on
Welcome to the club bdf.
Before you go any further you should run the troubleshooting tests which you can find here (post #9 at the bottom): http://www.polkaudio.com/forums/showthread.php?55888-POLK-AUDIO-Speaker-Wiring-Schematics-amp-More-Stereo-Dimensional-Array(SDA)
Do you have the interconnect cable that runs between the left and right speaker?
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
without the interconnect hooked on that pair of CRS i do believe that it would act just like the OP described.
Yes It appears the speaker need to be wired in reverse phase. How do I do that?Welcome to the club bdf.
Jim -
bulldogfish wrote: »Yes It appears the speaker need to be wired in reverse phase. How do I do that?
Did the red and black nuts on the binding posts get switched? On both speakers the red nut is to the left as you face the back of the cabinet.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro
