cross-reference parts for POLK RT2000P powered woofer driver?
kooshballa
kooshballa Posts: 5
edited September 2012 in Speakers
I need to replace my 8" powered woofers in my RT2000P speakers (rubbing the voice coil) but Polk does not support this speaker anymore. Additionally, parts-express does not have a x-reference for the parts either.
Has anyone replaced these successfully or can you recommend a replacement that is compatible with the built in amp?
THX
  • Whateverer
    Whateverer Posts: 57
    I'm interested in if anyone has done this also. My 2000p's are perfectly fine but its always good to know of replacement options.
  • nhhiep
    nhhiep Posts: 877
    I contacted Polk regarding woofers for my old SRT system. they suggested me to contact http://www.madisound.com instead.
  • kooshballa
    kooshballa Posts: 5
    nhhiep wrote: »
    Me too, but madisond and parts express don't have any cross reference data since it is an exclusive part to Polk.
    It looks like a pretty lightweight and inexpensive driver and ought to be similar to something out there currently being made but I struggle finding any real data.
