Show me your ****(embly), and let me get in your guts baby!
1303133353642
  • lanchile
    lanchile Posts: 560
    edited August 2012
    Make it simple...Make it better!
    EndersShadow Posts: 17,517
    edited August 2012
    lanchile wrote: »
    This is my diy passive integrated amp!
    Looks pretty cool!
  • lanchile
    lanchile Posts: 560
    edited August 2012
    Thanks guys! so far I have spent around $600 in parts. My last update was the potentiometer, now it has a TDK. I know with that kind of money I could buy a nice commercial amp, but this diy amp kicked my Bryston's B60 butts that is over $2k and beside it is unique lol!!! it is a small passive integrated amp 2 1/2 H X 8 W X 12 D. The amp kits are the M400 take a look the specifications:http://hdamp.com/M400.html
    edited August 2012
    lanchile wrote: »
    Pretty cool but I dont have the skills to assemble such a kit. Thats why I come here :smile:.... to make those kinds of connections :redface:
    nooshinjohn Posts: 25,034
    edited August 2012
    lanchile wrote: »
    Awesome work! DIY is a blast, and I cannot wait to take on my next project. Thinking I might go for a preamp next time.
    edited August 2012
    There's a shocker lol.... :wink:.. what ever happened to the SDA with ribbon tweeter speaker... I think that should be next..
    I look forward to whatever you end up doing.... you know I will try to make one myself someday lol....
  • lanchile
    lanchile Posts: 560
    edited August 2012
    Thanks! I would strongly recommend you to use TDK in your pre-amp. I did try Alps, Noble and TDK potentiometers and the TDK are way,way better than Alps and a step above of Noble potentiometers. They cost more money ,but it is worthy the extra $...
    edited August 2012
    The ribbon SDA will require a massive amount of skills I do not currently possess. I am finding the dipole designs to already have much of the same characteristics as SDA's have anyway, at least to my feeble ears.
    edited August 2012
    I will take the tip to heart Lanchile... I am looking at throwing a grand worth of tubes at my Sunfire to see if I can wake it up first, but from what I have been reading, the amps mine are based off of tend to roll off on the highs, Don't know why that is, but I will be checking with Bob to see what he says.
  • Face
    Face Posts: 14,340
    edited August 2012
    Goldpoint is another great attenuator.
    Did you use carbon pots in your amps like Bob does? If so, bypass them.
    edited August 2012
    I did not put in volume attenuators on my amps. I saw no need for them so long as I have balance controls on the pre.
  • Face
    Face Posts: 14,340
    edited August 2012
    Good.
  • zingo
    zingo Posts: 11,256
    edited September 2012
    Not mine, but I'd love to own it.
  • zingo
    zingo Posts: 11,256
  • Moose68Bash
    Moose68Bash Posts: 3,842
    I've got an interesting piece of equipment, pictures of which I want to post on this thread as soon as I can dig it out of the closet and take the photos.
    A little tease: Perhaps an iPod precursor?
    More to come later; I hope later today, but maybe tomorrow.
    Cheers!
  • nspindel
    nspindel Posts: 5,343
    This is the inside of my Dared MC-7P preamp:
    And this is the inside of my Dared MC-7P after I upgraded all the coupling caps with Auricaps:
    Clipdat Posts: 12,560
    NAD C316BEE:
    Beautiful! :biggrin:
  • Moose68Bash
    Cheers!
    Sorry -- it looks like I won't be able to post it till after my trip to Polkfest!
    edited October 2012
    Krell S-300i - Great design!
  • zingo
    zingo Posts: 11,256
    edited October 2012
    edited October 2012
    Love the "stealth" wiring around the toroidal. What kind of amp is that?
  • zingo
    zingo Posts: 11,256
    edited November 2012
    Clipdat wrote: »
    Balanced Audio Technology 200-VK; 100wpc at 8 ohms, 200wpc at 4 ohms high bias class A/AB (the amp bench tests at about 75% more than the rated power specs :cheesygrin:). The gets a hot as many SS true class A amps I've owned, but it still sounds warm and detailed with much more power and punch. Despite the sparse look in the chassis, because of the transformer and heat-sinks, the amp still weighs about 65lbs.
    SCompRacer Posts: 8,350
    Krell KSL balanced pre amp with Krell MM/MC Phono Board. Primarily Roederstien EK caps and Sprague. I've seen later versions with all Sprague caps. A nice TKD volume control. The first two are Carl's pictures from when it was first sold.
  • schwarcw
    schwarcw Posts: 7,328
    Hey Rich!
    I see that you have your tools out again! LOL! I took the first two pics, but the last two have your fingerprints on them.
    What a fabulous preamp!
    Carl
    Hey Carl! Just a little bench check, pop the top, clean, run an EKG and check pulse.:cheesygrin:
    Ed is trying to set me up with its old friend, the Krell-der KSA-250. Despite the age it is a very impressive pre amp and phono stage.
  • Gaara
    Gaara Posts: 2,415
    edited December 2012
    Recent purchase -> PeachTree Audio Decco65
  • Face
    Face Posts: 14,340
    Looks like they've beefed up their products a bit. Does this one have balance issues at low volumes like the original Nova?
  • lanchile
    lanchile Posts: 560
    These are the guts of my diy passive integrated amp.
  • Gaara
    Gaara Posts: 2,415
    Face wrote: »
    Not that I have heard, and I keep the volume between 9 and 11 mostly. I know they changed the amps to IcePower for the new Nova and Grand Integrated, and a chip amp for the Decco, not sure what other changes were made.
    Am looking at the new Nova now for the HT, torn between that and a W4S Mint. If I get it i'll be sure to pop the top and show the guts of that one to, though the only difference should be the amp.
  • Face
    Face Posts: 14,340
    I'm currently using a Mint, it's a nice sounding unit and should be a step above the new Nova.
