Wiring Polk Audio RM6750 to YAMAHA RX-V373BL
Wizxon
Hi, this is my very first home theater system and I am reading online on how to wire this stuff, but I am unsure.
I figured out the subwoofer with a RCA Y-Splitter, but my question is how to wire the speakers to the sub or to the receiver.
There are input/outputs on the subwoofer, and I'm not sure on how to connect them at all. Do I go straight to the receiver and ignore it, or do I go to the sub then the receiver or vice versa?
Any help is appreciated! Thank you!
Here are links for the items in question:
Receiver:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882115373
Polk Speakers:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290066
Receiver:
Polk Speakers:
Post edited by Wizxon on
Umm, bump?
Hello Wizxon,
Thanks for posting on Polk's forum. If you follow the illustration on page six of this owner's manual you will be fine:
http://www.polkaudio.com/downloads/manual/RM6750_MN.pdf
Regards, Ken
