trying new camera
leftwinger57
hoping this works ,been yapping about the stack for ages now
Talk about "heat score". That poor amp...
When I knew I was going to destroy my lame rack that I built I did a full 2 daypowered up test w/ sources running and there was no appreciable heat from the amp body or the rear fins. I've said this before but for whatever reason it's getting air and does not run hot.In a perfect world the tv would be wall mounted and then the gear would be on the console top.I personally think it's because it was a purpose built rack face gfa555 w/ room to breathe in there. Just my opinion and clearly not based on comparing 2 different models.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
