FX 500i or Fxi a6??
tophatjohnny
tophatjohnny Posts: 4,189
edited September 2012 in Speakers
Asking to see if anyone here can say as to which will be a better choice with the RT2000i Towers. For power at this time I am using my HK PA5800 and the Onkyo TXnr708 as the pre. My current surrounds are the Polk Fx300i so I am looking to upgrade the sound coming from beside the old comfy couch!! Anyone???:confused:
  • tophatjohnny
    Anyone????????????????
  • HTguru1982
    HTguru1982 Posts: 1,066
    Probably the FX500i. They will be better matched to the rest of your system.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • tophatjohnny
    HTguru1982 wrote: »
    Thanks, and I was thinking the same thing.
