Blown speaker?
KrisNicholas
KrisNicholas Posts: 2
edited September 2012 in Troubleshooting
I put an Olm meter on my speaker and it reads all zeros. Does that mean it is blown? I can't get any sound out of it because the amp is now blown too... I'm not sure if the speaker blew up the amp or vice versa.
Post edited by KrisNicholas on
  • ambiophonics
    ambiophonics Posts: 727
    Make sure your multimeter is set to a low range, probably the 200ohm or 20ohm range and see if you get a reading. Some meters are a bit confusing when to a high range if you try to measure a low resistance.
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • KrisNicholas
    Well the speaker is definitely shorted. One speaker reads 3 Olms, and the other reads 0. What would cause that to happen?
  • ambiophonics
    Well, the reason the meter reads "0" on one speaker is that the voicecoil of that speaker is damaged. Most likely there is a short in the voicecoil somewhere which would result in a shorter path through the VC which would cause your meter to read a much lower resistance. This damage could be caused by improperly powering the speakers (I don't want to get into a discussion of over/under powering) or some type of factory defect.
