8 Port Cable TV Amplifier
mrbiron
I bought this last year to replace the 3 inline splitters i had. I no longer need this nor do i see a future use.
I used it because we had a couple of cable runs over 75' and didn't want signal loss. During my basement remodel, i was able to drastically reduce the run lengths.
Comes with the plug, module, and i will include 4 cable terminators for any unused ports. You will need terminators to block the amplified signal leakage that your service provider will pick up with their trucks.
Signal Booster
$30 Shipped Cont US only.
Signal Booster
Post edited by mrbiron on
4th line down in the product features area states compatible with both standard and digital cable.
So i'm going to go with a big YUPPERS! :biggrin:Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
I don't know my @ss from my elbow when it comes to technical jargon on this subject. All i know is on my longer runs, it eliminated the slight snow by boosting my incoming signal. After re-routing my runs through the basement joists as oppose to going from basement to attic and then dispersing from there i found i didn't need it anymore.
The one catch is that you can't hook your modem up to it. You have to split the incoming having a separate line running to the modem and the other to the splitter. I trashed 1 Charter modem this way but was able to get a new one without a question asked. I should have done better research at the time.
Before i bought this sucker, i read probably a hundred reviews all across the internet and they were favorable.
When i get some spare time, i'll dig through the interweb, locate a few and post them here.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Pictures with what might be information?
$25 Shipped
Do i have to karma this too?!?!:twisted:Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Can anyone recommend an inexpensive solution to measure signal strength?
OK!!!
$20 Shipped Paypal'd and whatever else i need to get this thing out the door!Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
i have the same amp but i use it for my OTA.. since ive cut the cord with cabletv/directv this does all the distro from the stick in the attic. Really a great product. at 20 bucks a steal
Enjoy Vu.
Please mark this SOLD!Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
