8 Port Cable TV Amplifier
mrbiron
mrbiron Posts: 5,712
edited September 2012 in For Sale (FS) Classifieds
I bought this last year to replace the 3 inline splitters i had. I no longer need this nor do i see a future use.
I used it because we had a couple of cable runs over 75' and didn't want signal loss. During my basement remodel, i was able to drastically reduce the run lengths.
Comes with the plug, module, and i will include 4 cable terminators for any unused ports. You will need terminators to block the amplified signal leakage that your service provider will pick up with their trucks.
Signal Booster
$30 Shipped Cont US only.
Post edited by mrbiron on
  • mrbiron
    4th line down in the product features area states compatible with both standard and digital cable.
    So i'm going to go with a big YUPPERS! :biggrin:
  • mrbiron
    I don't know my @ss from my elbow when it comes to technical jargon on this subject. All i know is on my longer runs, it eliminated the slight snow by boosting my incoming signal. After re-routing my runs through the basement joists as oppose to going from basement to attic and then dispersing from there i found i didn't need it anymore.
    The one catch is that you can't hook your modem up to it. You have to split the incoming having a separate line running to the modem and the other to the splitter. I trashed 1 Charter modem this way but was able to get a new one without a question asked. I should have done better research at the time.
    Before i bought this sucker, i read probably a hundred reviews all across the internet and they were favorable.
    When i get some spare time, i'll dig through the interweb, locate a few and post them here.
  • mrbiron
    Pictures with what might be information?:confused:
  • mrbiron
    $25 Shipped
    Do i have to karma this too?!?!:twisted:
  • stargazer_97
    stargazer_97 Posts: 10
    Can anyone recommend an inexpensive solution to measure signal strength?
  • mrbiron
    OK!!!
    $20 Shipped Paypal'd and whatever else i need to get this thing out the door!
  • bruss
    bruss Posts: 1,039
    i have the same amp but i use it for my OTA.. since ive cut the cord with cabletv/directv this does all the distro from the stick in the attic. Really a great product. at 20 bucks a steal
  • haimoc
    haimoc Posts: 1,031
    ok... I will take it. PM you shortly.
  • haimoc
    haimoc Posts: 1,031
    SOLD.. PP sent. Tks.
  • haimoc
    haimoc Posts: 1,031
    Item arrived. Tks.
  • mrbiron
    Enjoy Vu.
    Please mark this SOLD!
