Wanted: Brimar Rectifier Tube 5Z48
CCNJ
CCNJ Posts: 384
edited August 2012 in 2 Channel Audio
OK, so I ordered the Dared SL2000a. I ordered some 12AT7 matched signal tubes from Brent Jesse audio but they don't have any of the recommended rectifier tubes in stock. Any one know where I can pick one up?
Thanks Chris
Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4
Post edited by CCNJ on
    heiney9 Posts: 25,497
    edited August 2012
    Have you checked Ebay? That's where I get all mine.
    http://www.ebay.com/itm/New-Unused-Boxed-5Z4G-Full-Wave-Rectifier-Vacuum-Tube-/110942640157?pt=UK_Mobile_Phones_Communication_Code_Keyers_Keys_Tubes&hash=item19d4b2581d
    The Brimar/English made are by far the best. Pretty slim pickings at the moment but that will change.
    edited August 2012
    Which 12At7's did you get from Brent Jesse? Hopefully you read through my posts to give you an idea of what's good.
    If I can help in any way pelase ask.
    edited August 2012
    These are French made versions of the famous Holland tubes (made on the same machines) and these are excellent sounding and this is a good BIN price.
    I'd recommend these.
    http://www.ebay.com/itm/Amperex-12AT7-ecc81-preamp-tube-pair-BB-/251140290615?pt=Vintage_Electronics_R2&hash=item3a7920b837
  • CCNJ
    CCNJ Posts: 384
    edited August 2012
    heiney9 wrote: »
    I did read your posts and picked up a pair of the Telefunken 5965s. I read about the microphonic issues but I wanted to start out with some really good tubes. I also ordered a Bendix 6106 rectifier tube but it was backordered and will take a week or so to get to me.
    Thanks for all of the great information you put into your posts. I had no clue about tubes a short while ago and am now slowly getting up to speed. I appreciate the offer to pick your brain if I run into trouble.
    Chris
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited August 2012
    OK - seriously considering the little dared and one or two more martinis tonight will probably cinch the deal
    This made me laugh,I think you will be a happy camper.I really like mine,Enjoy.
    Dan
