RTIA front stage color matching question.
Paphio
Paphio Posts: 7
edited October 2012 in Speakers
Hi, not sure if I should post this here since it is more of a cosmetic concern but I hope somebody know the answer.
Going through the site here for my new home theater, I saw the Rti a7 in the cherry color and really like the look of them. But when looking at the rtia family for a center speaker the csia6 and csia4 do look a lot more red in cherry.
On the other hand the TSIs have they're matching center color matching.
Is it only the pictures?
So beside going in black what are my options. Can I take the cs20 with some rtia or should I stick with the tsi line?
I would like to know before driving around to hear them.
Thank you
Paphio
Post edited by Paphio on
    F1nut Posts: 51,763
    edited August 2012
    The cherry version of the RTi A7's and either RTi center channel are a perfect color match. They are real cherry wood veneer, not something colored to look like cherry.
  • chumlie
    chumlie Posts: 8,658
    edited August 2012
    You have no worries. As F1 said they match beautiful.
  • Paphio
    Paphio Posts: 7
    edited August 2012
    Great, so the problem is only the site pictures.
    Now I'll go hear them.
    Thank you.
  • chumlie
    edited August 2012
    There power hungry. So your gonna want a quality reciever or amp to drive them.
  • Paphio
    Paphio Posts: 7
    edited August 2012
    Yeah I heard that,
    I'm planning on getting a denon 4311CI. Would it be sufficient?
    Paphio
  • chumlie
    edited August 2012
    I would think so. Do yourself a favor and get the csi a6 if you have the room for it. Much better soundstage with the larger speaker. IMO
  • Paphio
    Paphio Posts: 7
    edited August 2012
    my room is 15 x 12 feet. with half the side wall opened on dining room
    12
    ...| tv
    15|
    ...|...sofa...|
    something like that. Would the rtia7 and csi6 be good or too much?
    paphio
    edit : the ascii drawing get trimmed by the forum... I added "." to keep shape
  • devani
    devani Posts: 1,497
    edited August 2012
    should be good for your size....I use RTI bookshelf on my 13x19 room with opening to kitchen with equal size and stairs to 2nd floor...
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • badchad
    badchad Posts: 348
    edited August 2012
    I'm planning an identical setup in a similar room (20'X~25').
    As far as cosmetics are concerned, the only issue you may have with cherry is matching it to other shades of "cherry." For example, my coffee table is cherry, and it's a bit different than the RTiA7's. Similarly, some of the BDI stands appear as though their cherry finish is slightly different than the speakers (and different than the cherry coffee table).
    IMO, cherry finishes are tough to match. Your speakers will look identical, but may not match anything else.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • Paphio
    Paphio Posts: 7
    edited August 2012
    matching colors across furniture is not really a problem... I actually want those speakers in cherry to stand out from the living room (the rest is brown/black).
    so while discussing my setup, what should I get for surround...I'm planning 7.1. I was thinking to get 4 F/XiA4 since my couch is right next to the wall.
    Thanks again for all the advices.
    Paphio
  • badchad
    badchad Posts: 348
    edited August 2012
    I believe (and someone will correct me if I'm wrong) that your rear surrounds should be direct firing speakers.
    Personally, I'm opting for Rti4's.
    Polk Center: CSi A6
    B&K Reference 200.7
    Oppo BDP-103
  • Paphio
    Paphio Posts: 7
    edited August 2012
    oh, I was under the impression that dipole were better for HT setup.
    Hope some people can help with this
  • pdxfj
    pdxfj Posts: 376
    edited August 2012
    Di-poles are good for your L/R surrounds, but back surrounds (7ch) should be direct radiating speakers.
    Matching wood colors can be difficult.. I gave up and chose a cherry color to "compliment" my dark cherry tv stand/equipment cabinet.
    I wish my RTi-A speakers were in cherry, but since they are being moved into the dedicated HT black is fine.
  • Paphio
    Paphio Posts: 7
    edited August 2012
    Thanks my idea of back surround being dipole too came from this avs forum thread.
    Also 1 of my other choice of speakers is the aperion 5T that give you 4 bi-polar surrond in 7.1 config. I understand the direct back surround are the standard.
    I'll have to listen to both before making a decision.
    F1nut Posts: 51,763
    edited August 2012
    You want those or the FXi A6's since your sofa is against the back wall.
  • SugarmillMan
    SugarmillMan Posts: 175
    edited October 2012
    Agreed. In fact, Polk Customer Service recommends dipole mode for the sides and bipole mode for your back (rear wall) surrounds. Call and see....
    Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
    Subwoofer: HSU VTK3-MK3
    Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp
