20.00 Tube amp :)
onebadchad
onebadchad Posts: 364
edited September 2012 in Electronics
I figure I have about 20 bucks in it after i include the gas to go get it, the wire solder and tape to get it all working right.. A hi power 12ax7 pre with 12v6gt and 6l6 outputs. Stereo Tube Amp. aint real pretty but it rocks the garage with a cell phone as a source.
Dont have to be rich to go tubing :)
Hello Kitty am/fm CD player
Post edited by onebadchad on
    EndersShadow Posts: 17,704
    edited August 2012
    Nope, but you do have to know how to fix things if you go for the need repair type things. Thats what keeps me from lots of deals, I have NO SKILLS and do not have the time to aquire them. As such I either have to rely on others to help, or spend cash on items in working condition and those tend to cost a bit.
    Congrats on the score though, she looks pretty :biggrin:
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2012
    Looks like one out of an old console stereo
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    edited August 2012
    I agree that does look like its "pulled" out of something. But still a great buy at 20 freaking dollars! With Ender..I also don't have the requisite skills to tweak such equipment but I am desperately looking to pick up something on the cheap, lower power 8-12 watts for my KLH 17s. They sound just wonderful on tubes!
    Currently they're on my Marantz 2265 which is OK, but not "tubes"!
    I don't know how you do it. But these are incredible purchases you come up with!
    cnh
    edited August 2012
    cnh wrote: »
    cnh
    For me I am just going to go with some KRK Rokits or those Paradigm powered monitors in my office at the house. I just dont have enough space to setup anything really good and vintage (unless I find a set of CRS for a ridiculous price, and those are pushing it still)
    I wish my budget allowed me to run the Maggie Mini system as that would be friggin awesome!
  • pdxfj
    pdxfj Posts: 376
    edited August 2012
    Does look like it's out of a console radio. Got the same thing in my basement.. rescued all the tube amp guts out of a 50's or early 60's Sears console radio before it got hauled off to the dump. Everything works fine.. just have to take the time and clean things up. I'm sure the amp could use to be freshened up a bit with new components.
  • onebadchad
    edited August 2012
    This one is actually out of an Organ. but the console stereo amps work great. I proably have a dozen or so in the garage.. Easy Cl finds for 50 and under. Most dont require much technical skill at all just some cleaning up and a simple wood box makes a nice little amp
  • xsmi
    xsmi Posts: 1,801
    edited August 2012
    This amp is an old Marantz console pull. It was dropped into a modern JVC chasis and dressed up with a wooden face plate.The Marantz emblem was added to pay homage to the console it was in originally.
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • onebadchad
    edited August 2012
    Love it, good job.. Not only great sound, but the fact you did it yourself makes it sound that much better, so cheap and easy to do I am suprised we dont see a lot more custom jobs.. Im working on a Zenith this morning that I picked up last night. Ill post some pics later.
    mhardy6647 Posts: 35,013
    edited August 2012
    The OP's pull appears to be a two-channel organ amplifier.
    xsmi wrote: »
    Magnavox, not Marantz.
  • onebadchad
    edited August 2012
    It is, a Conn 59092. has a power supply big enough to power this amp and about another 100 tubes distributed through out the organ. I would hate to touch the wrong wire :)
    edited August 2012
    Those other tubes are probably mostly US-made 12AU7s and well worth harvesting if you catch my drift :-)
  • xsmi
    xsmi Posts: 1,801
    edited August 2012
    You're right mhardy! BTW, I just re-read my post! I didn't do this. A friend of mine did. I used it to power my SRS 2's for a short period of time. They were sublime!
  • amplifiedparts
    amplifiedparts Posts: 1
    I've been salvaging tube amps from garages sales/thrift stores for years. Yes, you got a screamin deal for $20. As someone else mentioned, you could probably sell some of the used tubes that came with it for way more than your $20 investment.
