Bass management
robert p
My Home theater Pre-Amp no matter what I do to it when I program it to integrate all the speakers robs my front speakers of there bass .What is the problem how do I eliminate this
Post edited by robert p on
We could better answer that if we knew your gear....how many and what kind of speakers,what amps, etc.HT SYSTEM-
lsi 9's -
I have an Outlaw 990 preamp a Levinson model no 23 power amp ,Rotel 993 3 channel amp,set of Maggie 1.6's set of Von Schwek VR 4II's a Martin Logan Depth Subwoofer and a paradigm center channel speaker.I also have a V.P.I. Scoutmaster table and a Rega Apollo CD player and a MSB Platinum Dac all M.I.T. cables
So which is being robbed of it's low end ? Not that they should have that much anyway since you have a subwoofer in the mix. Where is your crossover set at and have you played around with different settings ?HT SYSTEM-
lsi 9's -
Not to be glib - but isn't 'bass management' by definition 'robbing' the mains of the dangerous scary and harmful bass signals so that the sub can handle it?
What do you have the mains crossed over at?My equipment sig felt inadequate and deleted itself.
